Output coupling capacitors : value
Hi, I need to replace the output coupling capacitors in my tube-buffered DAC.
It uses a JJ 6386 LPG as buffer and then a pair of 2uF metallized propylene caps just before the outputs (together with a 1Mohm shunt resistor per channel).
I need to replace these caps.
I've been told that using higher capacitance here like 3.3 or 4.7uF will improve BASS extension : is that true? If so, what's the technical reason?
Thank you!
Gianluca
If you have a leak resistor of 1M in value and 2uF coupling capacitor, using the 3db point formula F=R*C then your responce goes down below 0.8HZ.
Way below any usable frequency!
0.1uF is a better choice. 4uF is far too large.
The cap with the load impedance form a high-pass filter.
The cut-off freq. depends on your load impedance (amp input impedance or whatever your driving with the dac)
2uF with a 10K load gives a cut-off around 7.96 Hz
Thank you!
Gianluca
What is the reason to replace the caps ?
And 6386 is a variable-mü tube, that has inherent dist. A 5670 tube would be a better tube in a buffer.
Thank you!
Gianluca
In a cathode follower duty even that kind of tube will sport low distortion can't prove it but can't hear a difference between a 6au6 and a 6ba6 both in triode mode in the same circuit 😀
There is a huge price difference between a 6386 and 5670 - to no use.
The 6386 tube is a remote cutoff tube used in limiters and compressors. No use in HIFI as it has no linear transfer if the operating point changes. Can be used with very small signals like in phono stages but not in as dac buffer.
The DAC (MHDT Stockholm V2) came with a NOS GE 5670 but the 6386 was in the compatibility list. Actually I had the chance to try-before-you-buy a JJ 6386 LPG (about 120 € for a brand-new tube currently in production) and the sonic difference was clear : the JJ 6386 sounds way better than the GE 5670 in this DAC.
A picture of the DAC board :
... but 1M is the security load to avoid uncharge , and in the real world, What is THE INPUT LOAD of the next stage ??? 😉
I went to 8uF for 56k 😛
2nd harmonics distortion sounds good "Mother, uncle...anyone can confirm that"
People here are trying to help and support you.
So a little appreciation is in place, don't you think?
Dear Lampie,
I thank anyone for the output coupling capacitor value matter.
The buffer tube is not on trial since I'm perfectly satisfied by the JJ 6386 that replaced the on-board GE 5670 after having the blessing of the designer.
Thanks,
Gianluca
