john curl said:We, high enders, have found that the coil changes the sound for the worse, and we have developed ways of making the amp unconditionally stable without it.
High Enders
john curl said:We, high enders, have found that the coil changes the sound for the worse, and we have developed ways of making the amp unconditionally stable without it. (at least most of us have).
Hi John,
Can you share with us, in general terms, what those ways are? I respect your need to keep some things close to the vest, but if there are a lot of "we" people doing it, there may be some aspects that are not proprietary.
Thanks,
Bob
CFP stages are attractive if designed with intellect
Hi David,
Conditions apply, such as Gain factor, Phase margin, compensation involved. I have implemented various types of CFP stages which are free from oscillation, very fast recovery from clipping, virtually free from saturation no matter how hard you drive them,Full powerbandwidth exceeding 50KHz,no output coil needed.
regards
Kanwar
lumanauw said:Hi, Toino,
Your attachment seems to be CFP output stage with gain. Is this output stage topology can always skip the output coil?
Hi David,
regards
Kanwar
Hi lumanauw
Certanly not!
The trick is in the C+R network on local feedback loop.
In my case I have achieved 40V/uS slew rate unconditionally stable.
10KHz square is not problem for 2uF capacitor on output, except that it triggers the
short circuit protection above a certain level.
And they are no rigging on the output squarewave with the capacitor connected.
With and without is almost the same.
Christer said:Is there any theoretical reason or just any hypothesis why the coil should affect the sound?
Ringing, silly.
G.Kleinschmidt said:
Ringing, silly.
See my flag?
I have some trouble with the English, sorry…
TOINO said:And yes.
Maybe that could explain why the coil affects the sound.
Toino,
Perhaps that is because any phase shift between voltage and current at the load is much reduced by the essentially resistive feedback of a CFP with gain? (I am not talking centre of gravity here!!)
This configuration would work even better if you could guarantee that the inactive device never completely switched off....
Hugh
Hugh
AKSA said:Toino,
Hugh
I now AKSA, but that is another story...
AKSA said:Toino,
Hugh
Just achieved in CFP,100% NO SWITCH OFF
Kanwar
Hi Workhorse
What are you talking about?
- Output coil on power amp...
