output capacitor in feedback loop for a unity gain buffer?
I have been reading about "Zero impedance line outputs" where the output capacitor is in the feedback loop of an opamp by means of multiple resistive paths back to the non-inverting input.
The issue is that the stage seems necessarily need gain to function, how would one go about including the output capacitor and 50 ohm isolating resistor in a non-inverting voltage follower?
Just take the feedback from the output side of the capacitor?
Unity gain buffers don't normally need capacitive coupling, as any input-offset isn't multiplied up, and many modern opamps have input offsets < 1mV...
Zero impedance outputs normally means the output side of the output resistor has a separate low-frequency feedback path. https://groupdiy.com/threads/zero-impedance-output.52076/ Of course you need the high-frequency feedback path as well for stability if the output is capacitively loaded.
BTW don't be confused by the circuit in that thread - the RHS is injecting a signal into the output to measure the output impedance, the large capacitor is part of the measurement circuit, not the buffer.
