I'm building an audio DAC and didn't think too much about output offset before actually turning the power on and measuring it. My bad!
I use passive IV conversion and therefore need quite a bit of gain. A +-2mV spread of opamp input-referred offset voltage gets amplified quite a bit, so the output offset voltage varies a lot.
What should I do?
- Offset pots on each channel? (=noise from reference source and expensive layout with multiple pots)
- AC coupling (don't like big caps and hi-pass filters)
- DC feedback servo
- Never mind, amplifiers are AC coupled
- What opamps are recomended by you guys for low offset?
Greetings,
Børge
What should I do?
- DC feedback servo
Greetings,
Børge
