output buffer for GC question
jsteigs said:
Is there a way to buffer the output of a gainclone like with a transistor or a MOSFET? if so, how would you bias it? or is the signal already to large to be sent into another amplifier?
Use a resistor divider if the signal is too big. That's all you need according to the little info we have.
Greg
Yeah, right. Let's amplify the signal at the reasonable level, then drop the voltage across resistor, disipate enough heat around and then again amplify through mosfet. :smash: I think jsteigs give himself an answer in his last sentence.
I assume that hidden attention is to make PA system from Gainclone amp.
