Our concerns about numbers, harmonics, distortion, square waves, THD, measurements
Interesting, Pavel & thank you for the plots - I really don't have any clue about the topologies but in my naivety I would suspect the purple & blue are feedback designs & the other two are non-feedback. My preference amp would be the one that produced the light blue (Magenta?) plot.
Edit: or are we looking at differences between Class A & Class AB here - I really don't know?
It would be great if plots of other known amplifiers were shown - I presume these were into a 8 ohm dummy load?
Yes Pavel.... low power performance is very important to me too
It is unusual to me to reproduce using more than 1 watt RMS average.
This thread is producing interesting results...i am very happy with this thread.
I have to test the 100 Kilohertz clock DAC... i had doubts about.
Carlos
How to translate measurements into something we listen... something very subjective someone (maybe Bear) have developed watching square waves... studying effects and results of some waveform...yes, there are traditional analises watching waveforms..but the translation to sound quality is something i could not read, listen or see till now a days.
I was inspecting some "tricky" capacitors into Aksa amplifiers to see the waveform effect...i could not..but i could listen the result...maybe i have used the wrong method to observe into the scope.
Despite i do not think brain can perceive square waves because delay into bio chemical processing, i feel great that someone can perceive things just watching square waves..i think this is possible, something alike virtual tool.... something alike:
" big slew rate numbers results this way "
"square wave showing low frequency losses may result into sonics that way"
"the biggest the bandwidth of an amplifier the best it will reproduce timbre (sound characteristic that let you discover what kind of music instrument is playing).... say...the harshing sound we have in violine..... the scratching sound from Saxophone...maybe into harmonics reproduced you may have the answer"
This can be very productive...it is a pity this is something as result of personal development..something not easy to be transfered to other guys.
Nice that... watching so many amplifiers into the scope with square wave input and listening to music made someone able to translate, at least to himself, what really means those oscilograms
Carlos
Yes Carlos,
very interesting thread with some real meat to it rather than continual bickering. Thank you Lumba for starting it.
I made a mistake in my colours in my last email - I meant I prefer the light blue (cyan) plot. We all know men don't know colours - peach is a fruit, jade is a stone, teal is a type of bird - no wonder we're confused
Cyan is nice to me too.
What makes an amplifier good?
This is the hell question... i do not know...and i do not know if someone has this knowledge.
So, despite measurements and evoluted technology we do not have answer for the most fundamental question.
well.... i have not... if you have please tell me.
Carlos
I have some ideas alike the transistor bias point...i felt 575 milivolts into VBE as something very good.
Also i found stable voltage to the input resulting great too.
I have found removing emitter resistances as sound turns better into bass
Something i have found..but about measurements and results i have not the knowledge.
I have noticed good measurements do not means nice sound.... not always...just sometimes.
I have perceived speakers as a big problem too... and crossovers (passive) as a hell thing.
Re: Back in the 80's
mosfets said:
...I purchased an amp once and it had a great THD spec of 0.001 at full rated output and it was the worst sounding piece of junk I (and all of my friends) ever heard. The amp had a strong market value based on its name and model number so I quickly recovered most of my money.
Shortly there after, I purchased an amp with 0.1% THD, and then I discovered that, published specs mean nothing unless you know allot about the people that publish them. Who are these people? What and why do they want to list these "specifications" about their equipment? Very Important.
Great topic by the way!
For ME...all of this is semantics. Now I feel listening to music is more important than absolute detail and some times fine details are so enjoyable but more often than not it is the passion or energy in the music that I continue to enjoy year after year.
I love listening to great sonic recordings that reveal every weakness & strength in my Hi-Fi.BUT I most always enjoy listening to old scratchy vinyl records that contain emotion that can make me cry or whatever….you know what I mean?
The MOSFET amp you bought surely did not have 0.001% THD at 20 kHz. The spec you are referring to is almost certainly 0.001% at 1 kHz (assuming you recall it correctly). This very different, and much easier to achieve. It sounds like you have possibly fallen into the trap of 1 kHz THD specs.
Bob
Hey guys,
There is something which may well be really important just above your posts from Pavel & then confirmed by Hugh Dean - the "Spectral distortion at low power into reactive loads is crucial."
This may well be one of the keys for unlocking the conundrum of measurement correlation to sound so let's try retain a focus on this until we can make some conclusions.
For instance. Pavel, would you care to give a synopsis of the sound of the 4 different amps in the graph without saying which is which & let people try to match the plot to the synopsis? Then we could later talk about topology that gave rise to each distinctive plot.
Hugh, without revealing any sensitive commercial information, do you have any similar plots that might illustrate the same?
PMA said:
Bob,
I have made a record of my standard power amplifier output level during my usual room listening conditions. My speakers have 94dB/2.83Vrms/m. It is a record of 1minute of Mozarts No. 41 Symphony  Jupiter, covering loud passages as well. As we can see, power output is no more than 250mW/4ohm. The quiet passage voltage is in tens of mV. Where can we see 1mW  1W spectra in Stereophile measurements, where can we see SFDR at these levels? The only plot is always the meaningless THD+N. Now, when you investigate amplifiers in this area of output power, you will find huge differences. They will never be shown in magazine measurements, as they are not politically correct. Then, we read that the measurements are meaningless.
The levels shown in my image are exactly those where most of amplifiers are in a transition zone of their output stages.
Pavel
Pavel,
You are quite correct, but that is no reason to throw out THD measurement. It IS reason to have it measured more diligently and in ways that properly include extremely low levels and exclude potentially masking noise.
Quite a number of bipolar class AB power amplifiers leave their class A region at as little as 50 mW into 4 ohms when everything is working right, and at that point are in the region of creating potential crossover distortion. When they are under-biased, either statically or dynamically, the situation is worse.
When reviewers measure THD+N and see it rise at lower power levels, they automatically assume it is noise coming up, and that is unfortunate.
Crossover and other nasty low-level distortion is quite insidious, and may be audible at levels as low as 0.01% THD, even when buried in noise. Noise is less annoying because it is largely uncorrelated with the signal. Our ears are adept at perceiving correlated impairments even when under the noise.
It would indeed be nice if reviewers would feed the distortion residual output of their THD analyzer into a spectrum analyzer under the conditions of these low test levels; they might be surprized at what they find.
Bob
Re: Re: Back in the 80's
Bob
The other trick is to so limit the bandwidth of the measurement that the observations are irrelevant -- 20kHz stresses a lot of amplifiers --
I must confess to using the 400Hz High Pass filter which makes it so much easier to separate out "hum" issues from "amplifier" issues. One problem at a time, please.
PMA said:
As you may guess, I would not write it if I had not results. We were collecting data of THD (spectrum), SFDR and noise floor of several amplifiers of different topologies in range of 2mW - 1W. However, I would like to see the same data from well known designs, as JC-1, Halcro dm68, Pass XA160, Ayre MX-R etc. Just a plot of THD of 4 'no named' amplifiers:
(someone might try to guess what are the topologies).
Hi Pavel,
Nice work with those plots. It would be nice to see what the residual looks like, both in the time domain and in spectra.
Bob
Bob Cordell said:
Hi Pavel,
Bob
Hi Bob,
if you do not mind, I'll give a link in my language:
http://hifi.slovanet.sk/bb/viewtopic.php?p=74467#74467
I believe the spectra are self-explanatory. They are for (50mV) 100mV, 200mV, 500mV, 1V and 2Vrms (5V) into 4ohm, 4 different amplifiers. But different measuring equipment and some are unfortunately cut below 1kHz.
Hi Pavel
In their measurements you used a loadspeaker, more the signal level is very low (1W) its speakers have difficulty in reproducing very low level, because is necessary overcome the mechanical strength of the speakers diaphragm. The reproduction of a transient signal would not be perfect as you measured.
Talking to a designer here in my country, he has a theory that to be considered an amplifier "High-End" must have frequency response in 20Khz, phase plane and distortion less than 1% in open loop....logical and low negative feedback too.
I do not know if this is true ?
Bob,
You have succinctly articulated all of the misconceptions about the value (or lack thereof) of THD measurements.
I may have done that in more detail elsewhere, not sure.
All the nonlinear distortion measurement standards are very old and have been widely criticized for their many flaws, especially for providing poor correlation with the perceived quality of reproduced sound. Several concrete proposals for improvement have been presented over the years, some of them taking perception and detectability of distortion and signal frequency content into account. These will unlikely be adopted by the audio industry, primarily intending measurement data for marketing purposes, however, there`s no apparent reason for DIY people to fool themselves.
THD with full spectral analysis is, however, quite valuable.
Very valuable, it´s essentially about spectrum, not level, that`s my point.
At the same time you have shown your lack of understanding of the value of simulation.
My understanding says that the value of simulation in that regard is zero, because the conjugate variables, position and momentum of a moving particle cannot be determined simultaneously. In other words, spectral components are not traceable at any given time instant.
I have posted this before illustrating the problem of THD metric, showing two signals having the same THD level. The distortion characteristics correspond very well with the subjective rating.
Hi John,
I'd prefer not to post details of my work. I am a practical designer, not much into the theory, and my measurement is quite basic. My work is deductive, based largely on psychoacoustic ideas, and listening tests form a large part of my assessement. To be frank, I like to avoid the fighting that punctuates these discussions and I haven't the time or training to examine the finer points of the math.
I agree emphatically with Lumba on his notions of distortion spectra. I think it's fundamental. Here's an FFT from LTSpice at 20KHz, 45mV peak input sine wave, loaded by 8R//100nF. It shows an interesting and extremely good sounding distortion profile with very low odd order distortion. H3 here, the large dip just to the right of the fundamental, is -73.5dB below 0dB, with all subsequent harmonics very, very low. This is a very low output; gain of the amp is 30.5dB, the output is 1.5V peak, a listening level where fine detail is present.
I'd be happy to discuss things privately.
Hugh
Thank you Hugh,
I understand your care in avoiding the quarrelling that drains energy & frankly swamps the often significant nuggets of information that appears here at times often from you and other skilful & thoughtful audio designers that pass by from time to time.
By aksa -Here's an FFT from LTSpice at 20KHz
Hugh , add this as the main directive in your lt.
.param num_fft_pts 16384
.param freq 20k
.param timestep {1/((num_fft_pts-1)*freq)}
.tran 0 10m 0 {timestep}
.options plotwinsize=0
.four {freq} V(c)
add this to your generator (ac source) "voltage"
{sqrt(.01)}
and "freq"
{freq}
make your output "C"
turn off all "compression" in "control panel/compression"
It seems as through your H3/5/7 are "hiding" beneath the
noise floor of the simulator.
It should look like this..(attached) Your "type" of topology
should be at least -85db H2 or better.. 🙂
