OTL amps for guitar duty
I didn't want to read all 73 pages on this amp, but skimming through, I got the impression some people found answers.
If anyone hasn't mentioned it, there are capacitor component designators repeated in the power supply schematic...that bothered me less than the output tube pin numbering error (based on assumptions about where pin 1 actually is).
I am apprehensive about the direct coupling and DC protection, but apparently Tim Mellow has one in his home and hasn't consumed any voice coils.
That fear remaining, I was thinking about a guitar amp with less costly speakers. I noted the availability of greater power output with higher impedance loads, but finding a 32-50 ohm voice coil seems like a big waste of time. 4 x 8 ohm speakers in series? Ugh? Would sound better than a bank of resistors, I guess.
I already have the tubes, sockets and applicable power transformers and it's not a terribly complicated amp...so it still has my interest.
OTOH, a mid grade Edcor OT for 6C33C-B isn't a lot of money. Or build both. Lack of time seems to be a bigger problem.
Nobody has reported speaker destruction when fed from this amp - YET.
OK, it's living dangerously but the sound from the amp is A1. If you accidentally knock one of the 6C33Cs out of its base, you get full HT across your speaker. It's a bit more difficult to build than you think; sourcing the right components was my biggest difficulty.
It would be be completely unsuitable for a guitar amp; it's really only for pure HI-Fi aficionados The sense of reward and achievement after building it is immense when you hear the end results. BTW, there is a previous thread on the same amp which is also very informative. Reading all posts on both threads is worth the effort - both inspiring and slightly daunting.
If you plan a guitar amp, there are 32 ohm 10" drivers intended for SVTs. !6 ohm drivers are easy to find.
I've been running OTLs for about 40 years and voice coil protection does not seem to be a serious issue. I think the old Futtermans could go into oscillation and fry tweeters and the like.
Most guitar amp designers and builders will argue that the OT is an essential part of the tone. So unless we're talking of an amplifier for acoustic guitar, there's little point to using OTL technology.
Sent from my phone with Tapatalk. Please excuse any typpos.
Thanks Atma, Aqua & Go-Di...
I'm not thinking classic hardcore overdrive Strat/LesPaul amp practices...
more like archtop...not entirely clean, but more clean that not.
I see plenty of jazz guys using solid state class A amps like the German AER amps.
I'm just trying to make an effort to build something with my hoarded oddball items that sort of aligns with my oddball interests...of the moment...
I joke that if I ever finish a project, a piece of my soul dies...if I still have it...I might have traded it for a box of capacitors...
yes, and power supply sag also, gives guitar amp its distinct sonic signature,
kit if crazy things these guitar heads do...😀
Yes, most guitar amps are atrocious from a hifi design perspective. The ones with more sag tend to be used more often for jazz and blues, rather than heavy rock and metal. Then you have Hiwatts whose OT had a 3.6Hz to 112kHz response! Anyway let's get back on topic 🙂
The funny thing about guitar players is how picky they are about their 'sound'. More so than audiophiles. But 80% of them play either a Marshall (or clones of it) or a Fender (or clones of it), but sculpting their 'sound' using effects pedals. The remaining 80% use something else- smaller combo amps, Ampeg, Vox or the occasional Sunn.
These days, many guitar players are really relying on their pedals. When you meet a player like that, an OTL guitar amp works fine for them. OTL guitar amps can have a soft clipping character that is very nice. But I have found that the preamp design is far more important!
Yes, because that sound is their "voice". However, IMO the starting point should be a really good amp, and not just a mass-produced Fender, Marshall, Vox knock off. Key points for the tone are first the transformers , then the tubes, followed by the caps and resistors. Cheeping out on those will provide a less than stellar experience. Once you have a real good quality amp, then you have the basis for a great sound and any pedals may just be used to add an optional dash of extra seasoning.
I've run into those that maintained that cheap carbon composition resistors are the trick parts for a guitar amp.
At any rate, if you want to add ferro-magnetics as a coloration to the sound of an OTL, its easy to do without using an output transformer! All you have to do is get a cheap interstage transformer and you're all set. That will allow you a very simple circuit.
The Edcor 3X15K-0 is a good example (having already used it successfully). I used this part to drive a Circlotron output section that was lightly biased (so no need for a bias control or DC Offset control), driven by a single-ended 6SN7 on the primary side of the transformer.
The amp I built can be seen on the Atma-Sphere facebook page
https://www.facebook.com/AtmaSphere...049334125840/1308663042497791/?type=3&theater
The photo is of the complete amp. The controls and input are on the other side of the chassis. Its all handwired, point to point. In order to be useful though with only four 6AS7Gs, it needs a speaker load of 16-32 ohms. There are several ways to do that!
My first attempt was a combo cabinet (which employed a separate power supply mounted on the bottom of the cabinet, power amp chassis mounted near the bottom and close to the drivers with the preamp chassis on top) that used four 8-ohm 8" Jensens in series for 32 ohms, arranged as a line-source array. This allowed for consistent sustain whether you were close or further away, and also allowed others in the band to more easily hear the amp without having to blast it while close up to the amp. You could also build it in a dual 10 or 12 configuration like a Fender Twin- that's my next attempt.
What I found with working with these amps is the preamp is far more important than the amp! The first preamps I built had far too much gain (6 volume controls, two channels plus a Fender style tone stack). You could really get some crunch out of it, but most players had no idea what to do with all the volume controls even though I had them pretty clearly marked.
The second preamp had less gain and less volume controls but still went too far. So I did the single-chassis version you see at the link, which dumped the midrange control (mostly out of space concerns- I was using a chassis that was designed to be a power amp and power supply). The single-ended driver configuration really helped with reducing the space needed by the driver circuit.
If you put the amp on an 8 ohm load it tends to make too much bass because the power amp does not employ any negative feedback. It would cut through a bit more if that were added, but I think that would work best if done as a presence control like you see on Marshalls.
Obviously its a work in progress! The amp section worked great from the very beginning; putting a proper preamp to it has been the issue.
Cool...thanks for the description.
I have heard this many times, and I do believe it's quite plausible. The logic being, "tone" actually is a misnomer for "timbre" in this context, and anything that creates roughly 10% or more harmonic distortion has the potential to change the timbre.
There are only a few components that can potentially create that much THD in a guitar amp, and those include the actual valves, the speaker itself, and the output transformer.
So it's certainly plausible that the output transformer contributes to guitar amp "tone". But it bothers me that I've never heard of anyone actually doing an experiment to prove it.
Oh, we have plenty of people saying that their guitar amp sounded better after they put in a $200 Mercury Magnetics transformer or something like that. Trouble is, there is no AB comparison possible, and human psychology dictates that you usually will think something is better if you just spent $200 on it. So these sorts of claims more or less fall into the "that could possibly be true, but it could also just be the placebo effect" category.
In principle, it doesn't seem too hard to come up with an experiment to test if guitar amp output transformers actually contribute to the amps timbre. Say, drive a guitar speaker with increasing amounts of sine-wave 500 Hz power, first from a low-distortion solid-state amp direct-coupled to the speaker, and then from the same amp via a 1:1 ratio output transformer made with the same-size iron as the actual valve amp OT. Or even two back-to-back OTs, one stepping the voltage up, the other stepping it back down, for an overall 1:1 ratio (less losses).
If you hear significantly different timbre via the transformers, the hypothesis is proved. If you don't, well, it turns out to be yet another amp-guru myth. Either way, we all learn something useful!
-Gnobuddy
