My to-read list:
Any books I should add? I'm aiming to build a set of speakers that I will hopefully never replace, so I want to get it as close to perfect the first time as I reasonably can.
- Loudspeaker Design Cookbook
- The Complete Guide to High-end Audio
- Designing, Building, and Testing Your Own Speaker System with Projects
- Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms
You'll find other suggestions in this thread: https://www.diyaudio.com/community/threads/precursor-to-loudspeaker-design-cookbook.383556/
THis thread may be of interest.
This tutorial is designed to get you started and tweaking a decent crossover… whether you're new to crossovers, or have built speakers before and are looking for a design method that relies on listening and doesn't require measurements.
The acoustic concepts apply to an active or passive crossover, since the needs of the speakers are the same in both cases. The simple but effective example crossover included here with formulas is of the passive type. With it you will achieve a much higher quality of crossover than possible using basic online calculators, and there is enough explanation to...
Not books, but papers in the "Basics" section of the Siegfried Linkwitz (RIP) blog.
https://www.linkwitzlab.com/
The Crossover Design Cookbook by Mark Lawrence is available here: https://calsci.com/audio/X-Overs.html
Slaughterhouse Five by Kurt Vonnegut. It's a very original novel.
Regarding loudspeakers, if you are also interested in DIY electrostatic loudspeakers, I can recommend the stuff my former colleague Frank Verwaal has written about them. It was never printed, but the pdf files can still be found on the internet (or at least they could, the last time I looked).
Jerry Mander, Four Arguments for the Elimination of Television. Old, but still very relevant.
You might want to drive those speakers with a quality amp. Doug Self's book on power amps is good for that.
Tom
Tom
In the past the LEAP website (by the brilliant, late Chris Strahm) had very insightfull application notes. Maybe one of our fellow members still has these?
My to-read list: Loudspeaker Design Cookbook
purchased the 4th edition many years ago ....... it was so disappointing i sold it on to some poor sucker.
Steve Deckers
But he so=oews a lot of slop. Beware.
“This is your Brain on Music” by Daniel J. Levitin. https://en.wikipedia.org/wiki/This_Is_Your_Brain_on_Music
dave
purchased the 4th edition many years ago ....... it was so disappointing...
Readers are often mislead thinking that they will be taught how to become proficient in doing something.
Not really, and not for some 40 bucks.
I consider it basically a sort of a scam.
- General Interest
- Everything Else
- Other books I should read?
