Oscilloscope issue
Thanks to all who suggested trouble-shooting strategies for CD63KI audio drop out. After checking the player's RF using a 20mhz Aron scope, the problem still persists.
I now have a GW Instek 653 (50Mhz) oscilloscope that may or may not have a fault. While the 20mz scope is able to generate a clear eye pattern for the player, the 653 only generates the section of the pattern to the right of section which indicates the triggering status. ( I hope this makes sense). I have tried adjusting the controls to resemble the older 20mhz but still the extreme left of the eye pattern is not displayed. I have attached pics.
Any advice will be appreciated.
It definitely looks like it is not triggering, try adjusting the trigger level manually, to be around zero volt with positive edge. But it is a little hard to tell, since the 2nd photo is so small and blurry.
Sometimes when a trigger is set to "auto", and the scope can't trigger, it will free-run, meaning it just triggers randomly and repeatedly so that you can at least see that there is a signal being input.
p.s. this thread probably should have been started in "Equipment & Tools".
