Hello,
First time poster!
I have a Lovely Cube which I've recently discovered sounds vastly better in 0 gain mode than any of the other optional gains (10, 18, and 20). I purchased a class A 3.49mA bias mod with OPA627 opamp modification when buying my lovely cube, as I heard the SQ improvements were well worth the cost.
My question, is whether I'm hearing oscillations because of my amp being at 0 gain; it being potentially impossible that my OPA627 is stable with the class a bias mod in 0 gain mode (at 3.49mA); or if I am indeed hearing a stable opamp at 0 gain.
I've read that with a class A bias modification, you need gain to make the chip stable; however my confusion comes from the chip sounding better at 0 gain in class a than any other gain setting. Any clarification here would be greatly appreciated.
Oh, and my headphones are the HD650's if that makes any difference.
Thanks!
First time poster!
Thanks!
Not true, OPA627 may very well be stable at gain of 1x (0dB) with or without class A output biasing.
If the opamp is used in non-inverting mode, 0dB gain subjects it to full common mode voltage on its input, while 627 handles this remarkably well, you might find further improvements in the 3x - 6x gain range. For 10x gain, you might as well use OPA637.
