Oscillation in effect loop
Good layout is too big a topic to cover easily, and it's a bit of a "soft" skill, half art, half science. But here's a little write-up to get you started: How to Layout and Build a Guitar Amplifier Chassis - GuitarKitBuilder
That write-up is very incomplete - it only really talks about physical placement of the main components. It doesn't address wiring at all, and the wiring layout can make or break the build.
I'll see if I can find a good wiring layout write-up somewhere (there must be some!), but in the meantime, some general guidelines off the top of my head:
1) Keep wires as short as possible, within reason (i.e. don't fight to shave a millimetre off the length, but shave off an inch whenever you can.)
2) Don't run signal wires side-by-side and close together.
3) When possible, cross signal wires at right angles or nearly so.
4) Keep wires carrying low-level signals far away from wires carrying large signal voltages.
5) Keep output wires as far from input wires as possible - at every gain stage, as well as over the entire amplifier.
6) Route wires flat against the grounded metal chassis when possible; this reduces hum and noise pickup.
7) Use shielded cable (coaxial cable) for sensitive wiring carrying small signal voltages.
8) Distance is your friend in many cases - space wires further apart, keep outputs well separated from inputs, position gain stages a few inches apart. (Yes, this appears to contradict item #1, and you have to figure out a reasonable compromise.)
9) Grounding within the amp is critical. This is a whole topic by itself; the chapter on grounding schemes in Merlin Blencowe's Tube Preamp book is well worth reading.
-Gnobuddy
The best advice I ever heard (I think first phrased this way by Lynn Olson) was
"think in loops"
Current flows in loops; voltage adds up to zero around loops and magnetic coupling happens in loops. A twisted pair is an anti-loop.
Capacitive coupling does take a little more visualisation but it's still in a loop. Shielding trys to block or cut loops. Static is probably the odd man out here but that's usually only a problem during construction
