Hello
Looking at the Attached Circuit, I would appreciate any comment as to why this Guitar Power Amplifier circuit does not have any sort of Zobel Network on the Output Terminals. This Particular Amp I am working on is suffering from an amount of high frequency instability, and I was thinking that it might be appropriate to add one?
Thanks for any insighthttps://www.diyaudio.com/forums/attachment.php?attachmentid=961398&stc=1&d=1624257194 -Telnet100
None of the other amplifiers of this design have a network and they are fine until the output transistors or MC1436 are replaced with Chinesium fleabay replacements. Then you will get issues much like yours. Check the PFLoop components, yes Possitive Feedback Loop R133 etc, it compensates for poor loudspeaker efficiencies at odd frequencies to try and smooth out the response.
I suspect, if original, the issue is elsewhere and the amplifier is only reproducing what is on its input.
Hello
Thanks for that -- I will do a suggested, and maybe try to disconnect the Input from the Power amp -- easy to do on this, as You only have to plug an unconnected 1/4" Male plug into the Stereo Return Socket, which then isolates the power amps.
I will report --
Regards, Telnet100
I will report --
Regards, Telnet100
You sure of that Jon? How do you see that loop, either the AC or DC portion, as positive feedback?Check the PFLoop components, yes Possitive Feedback Loop R133 etc,
It is negative feedback for me, but it is current feedback, the feedback is current-sampled instead of the more common voltage sampled. Maybe that is what Jon means.
Jan
Jan
Many times in a guitar amplifiers the OUTPUT Z is boosted (POSTIVE FEEDBACK) and lets the speaker RING. Maybe your amp has too much feedback?
Duke
Duke
Current sampled for the AC FB, but there is also a more conventional DC path through R120 et al.It is negative feedback for me, but it is current feedback, the feedback is current-sampled instead of the more common voltage sampled. Maybe that is what Jon means.
I would change C68 +C69 first , the IC is internally compensated .
Maybe add C67 to that list?
Perhaps if you would expand on what you mean by high frequency instabilities. What symptoms are you seeing?This Particular Amp I am working on is suffering from an amount of high frequency instability
Your right I missed that one --your thinking is the same as mine.
- Oscillating Amplifier
