i could use some help with this amplifier. Starting with the power supply. The gate drive past the resistor doesnt look right. the photos are of each side, pre resistor and at the leg of the mosfet.
271ohm per gate?
rail, and regulated present.
+-135vdc
+-12.5vdc on the op amps.
3.2amps of current at idle.
Seems to be running ok, just no audio
271ohm per gate?
+-135vdc
