Orion HCCA5000.1D
Amp powers up and idles fine power supply fets remain cold .
But this is what I get on the gate leg of the power supply fets .
Is this normal for these amps or do I have a problem somewhere ?
Scope set to 5us 5volts/div
If you can try Nd get the audio section oscillating and recheck waveforms in the power section. Should see around 6 amps at idle. This one requires an audio signal to oscillate. I dont remember if this made a difference or not. I know by reducing the voltage i dont see any change in the waveforms ether.
