Orion HCCA D2400
This amp is in some kind of shutdown mode.The power led is on and the ESP led is blinking.I see no rail voltage.
SG3525
1: 0.00
2: 5.15
3: 0.12
4: 0.382
5: 2.072
6: 3.766
7: 2.017
8: 0.262
9: 6.42
10: 1.586
11: 0.035
12: 0.001
13: 13.23
14: 0.007
15: 13.24
16: 5.17
393
1: 0.086
2: 3.994
3: 2.729
4: 0.000
5: 0.058
6: 5.17
7:0.125
8: 13.21
Any suggestion?
Do you have good audio on the pre-relay audio if you load it with a speaker or dummy load? Connect the negative load wire to the negative speaker terminal.
I know nothing about the ESP board. There are threads about them.
Look up the owner's manual for this amp to see if it gives you any information about the code the amp is giving with the LED.
The led is blinking like every second ,in the manual and can blink that way for more than one reason .
I just realize the esp led will only blink when remote and B+ Voltage is applied the same time.If remoter is apply last like it should only the power led it on but amp still in shutdown mode.
