I have an Orion hcca 250r that I have been working on. I actually had it working but then decided to replace all the BJT's to make sure it would be consistent. Since I have done this I now blow fuses as soon as I put in the fuse. I need to make sure that I didn't screw up and possibly transpose the rectifiers or put something where they shouldn't be. A close up of both side would be great. Thanks. Scott
The amp has the 6491s near the RCA end of the board. There are 5, then 5 6488s then 5 6491s then 5 6488s.
The other side is all power supply FETs.
The rectifiers are under the board.
