Orion HCCA 225 Gen 2
This one came in with half the PS blown, and half of each channel BJTs. I'm troubleshooting the power supply with rectifiers removed, and I cant get the original blown fets now replaced with IRF3205 to not over heat. I also replaced the other side's PS fets which were not blown so all matching IRF3205 now. I found a 12v ZD near the corner of the board just near the inside speaker terminal had also blown short. The PS fets which get hot are the ones also near the speaker terminal. Drive signal to the gates without fets looks strong, but when installed the drive signal gets a bit wavy even when fully driven. I also replaced all MPSA06/56 drivers in the PS. Clean square wave is coming off the TL494. When I apply 14.4v, the amp powers with rects removed and only draws about 0.3A. When I drop input voltage to about 10vDC that side of the PS FETs will overheat and draw excessively. Its defiantly a weird one IMO. With rects installed that same side of the PS overheats easily at any voltage. I've serviced a bunch of these 225HCCA amps but this one is getting me.
The drive signal looks OK, maybe a bit poor on both sides of the PS for my liking but both sides are matching and the other side stays absolutely stone cold.
I think the muting circuit may operate on the faulty side of this amp.
This amp was severely over-loaded, and possibly over-volt. I found both rail caps partially detached and replaced both and the main PS filter caps.
Why does this amp draw excessively when input voltage is dropped?
Yes those 10o resistors are measuring fine on ps pnp collectors. The ps drivers actually never failed.
This is the scope at 2vDiv. The scope is calibrated. Probe on the gate leg of a fet. Both banks are the same one bank gets hot. No rects in circuit.
Pin 9/10 of the 494 are 0v or above.
