Orion DEQ30
i tried to find the schematic, no luck whatsoever, i can hardly find ppl who have working ones much less the circuitry behind it.
The 9540 did turn off the power going to the rest of the board. YES. i did not check for any voltages though because of the LED which switches on and off
no offense taken ! LOL....i kno, i think its my limited knowledge slowing down things.....much thanks so far.
So use the continuity and go from point to point, do i need to power it up to test that or is it fine without ? I had started but i got a bit confused not sure if i was doing it correctly,
Once i get back to it i will use some red lines and see how far i can get if im wrong at any point hopefully u can help me out. resting ma brain for the day so monday evening i will be back it.
