Orion 2150GX trouble powering up
I did the measurements for both optocouplers 2 different ways.
First, referencing CT
Coupler on the right in previous photo, closer to Right channel (Precisely the one you suggest me to measure)
Pin 1: -0.113
Pin 2: -0.121
Pin 3: 0
Pin 4: -4.002
Pin 5: -3.968
Pin 6:- 3.430
Coupler on the left in previous photo
Pin 1: -0.119
Pin 2: -0.127
Pin 3: 0
Pin 4: 0.003
Pin 5: 0.024
Pin 6: 0.025
Second measurements were referencing amp's general ground
Right
Pin 1: 1.208
Pin 2: 0.007
Pin 3: 0
Pin 4: 0.129
Pin 5: 0.129
Pin 6: 0.129
Left
Pin 1: 1.147
Pin 2: 0.007
Pin 3: 0
Pin 4: 13.87
Pin 5: 14.00
Pin 6: 14.48
Fully off and unhooked there is no resistance at all between primary and secondary. OL on the meter. Open.
My source tests were from a car head unit or a frequency generator. Both with sine wave both were exhibiting the same behavior.
Yes there’s only 55ohms between amp primary ground and head unit rca shields when RCAs disconnected. Both running from the same power supply.
Re-verified a few things
1. With muting transistors installed;
8~10vDC on speaker terminals.
Lower waveform of right channel not as strong as left channel bot both may have some faults.
Rail voltage 'shifts' by -5vDC on both sides.
2. Without the muting transistors
No significant dc on speaker terminals
Clean waveforms on the scope all the way to clipping.
Rail voltage stays stable.
Amp could likely pass as fixed without the muting circuit.
Amplifier pulls 67amps off the bench on a sine wave just at clipping. Each channel at a 2ohm 12” subwoofer load. One sub per channel NOT bridged.
Call me old skool but I'd like to fix this amp as much as I can as long as parts are available. I don't feel right in leaving the muting circuit out. I bet if run in a car it could cause issues.
Head unit to unit's disconnected RCA shields measures 2ohms.
Amp primary to secondary grounds are OPEN. OL. For a brief moment the meter was measuring 20million ohms but then it went OL.
For these readings:
Pin 1: -0.113
Pin 2: -0.121
Pin 3: 0
Pin 4: -4.002
Pin 5: -3.968
Pin 6:- 3.430
Pin 4 should be much lower. The attached diagram may be similar to your amp. Suspect the 22uF cap and the 220k resistor.
Its actually a 10uF cap and yes a 220k resistor. I had to lift the 220k to measure it, and its measuring ok. The diode just next to the 220k is also ok. The 10uF cap I actually replaced as I replaced all the 10uF caps on the board because I found one had opened up and was blocking the right channel signal just behind the RCAs yesterday; way before where I am now.
Do you have a full schematic for this or similar amp? I'd like to check everything connected to pins 4/5/6 of the coupler.
I've tied the ground together. RCA shields measure 0ohms to both grounds.
On the 220k resistor,
-39.2vDC
-4.32vDC *
Pins of that Octo:
Pin 4. -4.32 *
Pin 5. -4.26
Pin 6. -3.70
* connected
Also I ran a diode check against both Optocouplers. They seem to be OK across pins 4/5/6.
