Original JBL control SB 5 driver .... what can i do with these?
After being itchy hands of modifying my JBL control sb5 subwoofer unit with other china unit drivers ... i am left with the original units hanging around (total of 4 pcs 🙄)basically doing nothing around my storage area 🤣 they actually and originally configured using tri chamber 6th order bandpass system ... i wonder if what i could come out with something different with these drivers? from the looks they dont seem to be very solid build but their sound is indeed very solid ... i am thinking of ported for these drivers but they dont seem to have very long throw ... any other ideas? thanks
You should perhaps point out, danny, that your middle image shows the two "other'' drivers that you installed in the triple chamber bandpass enclosure instead of the original four JBL woofers.
You would need to know the T/S parameters of these JBL woofers in order to design suitable ported enclosures for them.
i wonder if what i could come out with something different with these drivers? ... i am thinking of ported for these drivers
Well, a max flat BR is ~63.64 L/48.3 Hz, so four is a fairly impressive ~254.55 L/8.99 ft^3 net before bracing, material thickness is factored in. Stuck in a corner will somewhat compensate for low Xmax.
