Also, I stay away from tap water, unfiltered
There is a reason they call it tap water and not drinking water.
Many people scoff at it. The system was discovered by a German doctor Dr.Hanneman who was also scoffed at initially due to the enormous dilution of some of the 'medicines' . Unlike alopathy , the more dilute it is the more potent it is !
I OD'ed on a homeopathic medicine once. I didn't take it.
maybe the water curbs your appetite for a duration so that you eat less, healthier during that period.
Too much water is a tough thing to pull off. The real issue is making sure you aren't flushing out all your electrolytes. Eat a healthy diet and ensure it's balanced.
Someone prescribed water for my daughter's dyslexia, we started to figure that maybe Rudolph Steiner didn't get it quite right.
Dentist measures BP in my right arm at 170, but only 135 on the left.
This happened more than once and I have to question her competence
to take a simple reading... Why go to a dentist to have BP measured?
I wouldn't even be using this lame-o, excepting she's only one that will
work with my crappy insurance.
It's worth getting your own BP cuff in case you really have high BP. Yes, it is possible to have differing BP in each arm, or leg.
That's a possible sign of blockage. BP medication is generic, cheap, and effective.
(Still reluctant to blame Yukikazu Sakurazawa ?)
In a former life my wife knew Michio Kushi still going at 88.
Either reading is high enough to talk to a MD.............................................
Get yourself a little (but smart) BP meter.
But just reading BP doesn't solve possible problems.
I'd like to ask Ashok if he orders a serve of homeopathic scotch is a bar.
You know, one drop of scotch in a glass of water.......
The real harm of this nonsense is that they have homeopathic inoculation where they shoot water into babies and the fool mothers believe the child is protected.
How many of you have a glass of water with your espresso ? (average Italian hits 83, afair)
Proper sequence: Water, espresso
George
Proper sequence
With your batting average, you must have the fluid retention skills of a camel, Mr Papageorgiou.
Was only 125 at the grocery store pharmacy...
Nobody bothers to calibrate these damn things.
If possible take it in both arms, they should be very close. Also, don't immediately repeat a test in the same arm.
Allow some time, maybe 10-15 minutes, before a retest.
You didn't read my post carefully. Dilution is not done in a simplistic way !
The method is called "Succussion". Look it up !
Shooting water into a person is NOT homeopathy. Don't pick up all kinds of things and call it homeopathy. I've never come across 'homeopathic innoculation' !
I did a search and came across this "Homeopathic Alternatives to Vaccines".
So there is no Homeopathic innoculation like you mentioned in your post! Possibly some nonsense written by someone and believed by the 'reader'.
If you don't like the word or system ( homeopathy) skip this post. However do remember this is NOT a post about homeopathy in the first place. It was about Water Therapy and 'homeopathy' was brought into it !
So it might be a good idea to stick to Water Therapy and BP issues in this thread.
Cheers.
Life is full of fun
Winners in the colonoscopy lottery have to prep themselves a couple of days ahead of the big event, low fibre diet, laxative pills/solutions, the works.
An generous hour before they go live on stage, the lucky stiffs may receive an enema behind the curtains.
At least two out of three merely turn out to be anal retentive types, some days four out of five. Bad diet, not intaking sufficient fluids in a 24hr period, slow functionality of the ascending/transverse colon, etcetera.
The uptight buttock ones, who will poop the walls 3ft high within five minutes after the vacuum injection, can already be picked out visually from the line-up in the corridor.
(I worked in radiology for a few, the majority of my freaky remarks have at least fifty percent truth in them)
- Member Areas
- The Lounge
- Ordinary WATER as a medicine.
