Optimum Opamp setup
I've seen various posts and comments hinting towards the way opamps should be used to reduce the possibility of oscillation and other non-positive artifacts in their usage.
I was wondering though what are things you should always do in opamps to ensure optimum performance.
Mine are going to be used in an active xover powered via batteries. Cheers for any advice Matt.
Read (carefully!) the datasheet for the opamp in mind. In work and otherwise I ALLWAYS get the datasheet and read it from page 1 to the end. Do that!
Don't use too high values of resistors (feedback in particular). Make sure that the high frequency impedance of the supply voltage is low. 10-100 nF close to supply pins and a good signal ground. Don't use faster opamp than needed, very important if you don't have good pcb's.
It's easy to succeed if you follow these simple rules.
I dont know whats considered super fast opamp but im considering using opa2134 and opa627. The idea is to prototype with preset resistors on veroboard etc and get the filters sounding the way I want them too and then Ill build a PCB with permenant value components appart from gain matchin which I will leave variable on the addition of a different amplifier, with different gain.
I have used the OPA627 bread boarded and it worked fine without any extra parts to ait stability. All that was used was the 12db filter bits and the battery power supply. I then vero'd this and it didtn work I got all sorts of strange problems with distortion and white noise. The 2134's didnt produce white noise but produced strange problems too which included distortion.
At the moment my active xover is build arround tl07x and are very simple, buffer stage and then the 12db roll off for 4 channels. This works fine no probs without any instability or hum problems.
I want to get better quality opamps working as they do sound better and I was just interested in the do's and dont's of opamps.
On that PDF file (very very long!) The only thing I kinda got was caps from the power pins to the ground and then from you caps to the opamps power supply line. Is that about all that is needed for stablility?? appart from super pcb layout.
Cheers again Matt
values
I would say not higher than 100K in feedback is safe. But it depends on many thhings, layout is one of them.
Most audiio mixer schematics I've seen use 22-100K max, depending on what the opamp is doing.
Mackie designs has a VLZ series where it uses very low resistor values, increasing current consumption and disipation. Not good for batteries, of course.
cheers
Ric
Re: values
cheers
Ric
we use 220k in the gainclone:scratch:
