I been running two 4R subwoofers lightly with the KM1700. So far, not bad, not bad at all. The fans are there but pretty unobtrusive (with the amp right up front and not hidden, etc.). I have two new 12V "quiet" fans on order to replace the two 24V stock fans. Hopefully I can simply connect the two new fans in place of one of the old. The current and voltage specs of the new and old fans seem to indicate that is totally possible. The airflow with the new fans will be about half of stock, but because the amp will be used in a home audio setting instead of for PA duty and will have an open airflow path my guess is that it will be fine. I might try some thermal measurements before and after the mod if I have the opportunity.
As an aside to Charlie, The DC fans as used in personal computers can be readily and reliably slowed down by simply adding series resistors.
I found in the past that 12v PC fans would start reliably with 7v applied, with almost zero subsequent fan noise. A 50r series resistor will get you there!
+1 on this approach. The series resistance you want to use will depend on the fan's resistance so this is by no means "universal". Instead, if you can get some data on the fan you can calculate the series resistance value. It should be rated 1W or more.
Here is how to determine the resistor value:
1. Get the MFG specs of the fan. You want to be able to calculate the fan motor's resistance, Rfan. You can do this from its rated voltage and current consumption, which are typically included in the specs, using V=IR --> Rfan=Vrated/Irated.
2. Make note of the minimum operating voltage, Vmin, specified by the MFG. This is the voltage at which the fan will reliably start.
3. The equation V=Vrated*Rfan/(Rfan+Radd) can be used to calculate any Radd that you would like to use. Note that V must be greated than Vmin! The fan speed (and likely the airflow) is proportional to V/Vrated.
The quietest operation occurs at the minimum speed, which will be obtained with the fan running at Vmin. This will also provide the least amount of AIRFLOW through your amp. A quiet fan that moves too little air will increase the thermal stress on the components and may cause the amp fail sooner (have a shorter lifetime) and it may go into thermal protection when driven hard. Choose wisely.
Another consideration is the back-pressure that the fan sees. If your amp is installed in a cabinet with little room for airflow, the fan must work against the resistance created by the restricted flowpath and this will reduce the fan efficiency and its total airflow. Most "quiet" or "silent" computer fans have very low static pressure ratings and will quickly lose efficiency even with very little airflow restriction. This is why you often find noisier fans in pro audio amps: they can operate into higher static pressure and have a higher no-load airflow capability. These are needed when the amps are mounted in tight rack cases that are hot. In a home application, you can provide better access to cool air and the average power demand on the amp will likely be lower, so a slower and quieter fan is very likely sufficient.
I just replaced the two stock fans with "quiet" (12dBA) 12V computer case fans. The stock fans were rated at 33dbA, so the new ones are about 20dB quieter. Nice. I thought I would share my experience in case anyone else wants to try it.
There are two 24V fans on the amp. Each is fed by its own 2-wire V+ and GND wires from a regulated DC supply on the output device PCB. Since computer case fans are 12V and you need two of them, you can simply wire them in series and power the pair via one of the stock fan leads. Simple! I cut off the unused fan lead at the fan and disconnected its molex connector from the PC board but left the wires in place (they route under the PCB). After soldering the new wiring and re-insulating the connections I tested everything with the cover off before putting the cover back on.
NOTE that there are quite a few screws to deal with: to remove the cover you remove screws through the top at the front and rear, and from each side just below the top. Additionally, there are four screws on the bottom and four more inside at the corners of the output device PCB. You must remove all of these because the heat sink and output device board assembly needs to be slid forward about 1/2 inch to get the stock fans out. All wiring can remain connected during this process.
All-in-all this was not too bad of a job and now the amp is practically silent. In a very quiet room with no other sounds to mask noise I can barely hear the fans from about 3 feet away when I listen for it. The amp does not produce any hum or noise otherwise. It's plenty quiet to use in a home setting.
Hello,
I was wondering whether you are still enjoying the amp. I am also thinking to pick up one for dual 1260w subwoofers (4ohms - 300w rms) to be used in bridged configuration.
Best.
This assumes a constant resistance of the fan, regardless of speed, which is not the case. In reality, fans have a lower resistance when standing still. So the voltage drop across the fan will be lower than calculated and the fan might not (reliably) start at all.+1 on this approach. The series resistance you want to use will depend on the fan's resistance so this is by no means "universal". Instead, if you can get some data on the fan you can calculate the series resistance value. It should be rated 1W or more.
My KM1700
I love the KM1700. It is extremely fast, quiet and powerful.
I added a 300 ohm, 5W Xicom ww resistor in series with each fan. This quieted them down to acceptable levels and should not result in cooling problems with my home use. After 18 months, so far so good.
The 1700 uses two Ametherm NTC Inrush Surge Suppressors to reduce the turn on surge caused by the approximate 1.5kVA toroidal transformer and four 10,000 uFd electrolytic caps. The amp has dual secondaries and is dual mono from there.
The very high quality pcbs use a mix of surface mount and through hole components. I replaced all of the electrolytics in the amp with Nichicon Muse andFine Gold and Elna Silmic II audio grade types.
I believe the 1700 employs current feedback judging by a JRC transconductance chip in use. This undoubtedly contributes to the high slew rate, in the neighborhood of 500 v/usec as mentioned in a Gernan blog.
Four op amps for balanced to single ended conversion. etc. are TI 5532 8 pin dips.
All wiring is 18 guage or heavier and well routed
There are trimmer adjustments for dc offset and quiescent current bias.
The input level pots appear to be of high quality, but I cannot discern the manf.
I added a sheet of a/c filter foam to the entire inside front panel. I was not able to find my preferred Filtrete cut to size sheets at Home Depot or anywhere else this year.
There is no flux residue on either side of any of the pcbs.
This amp has a continuous output of approx. 125 wpc with 6 dB of dynamic headroom to yield 500w on peaks. I plan to add four 4700/63 Nichicon Fine Gold ecaps to each of the four supply caps.
This is a killer bargain among power amps. If not known, I would estimate its retail price at $600-$800 easy.
That should read the transformer has dual secondaries.
Also one 4700/63vdc Nichicon Fine Gold electrolytic cap. In parallel with each 10,000 uFd/63vdc main supply filter cap for longer peak reserve.
I also twisted off the red and black knobs on the binding posts to access the banana plug. They are not the kind with a pull out center safety plug.
Simply twist the binding post knobs hard fully counterclockwise and they will strip off, revealing a much more useful banana plug.
Can't stress enough how amazing the transient response is with the 1700. Behringer credits the ON Semiconductor output devices, but there is more to it.
Hmmm...
FWIW, 1/8th power is pink noise with a 9dB peak-to-average ratio run so the amplifier is just clipping. Sine wave testing is still technically only half-power, since it has a 3dB peak-to-average ratio. If you want to really cook an amplifier, you'll need square waves, where the peak-to-average ratio is 1.
Chris
On a purely ohmic load, square waves at full power level would not cook the amp itself - if the amp is Class AB or H - but put high load on it's PSU. The amp itself would not be very much stressed since there is almost no voltage drop at the transistors. Sine wave testing would put way more heat to the transistors and less load on the PSU.
In case of purely ohmic load and Class D amp, both the amp and the PSU get stressed more with 0dB square instead 0dB sine.
Real loads are not purely ohmic and that makes the whole situation even more complicated - with a BIG advantage to class D over AB and H in that it has higher efficiency AND can recycle instead of just burn reactive energy and therefore get away with a less powerful PSU for same output.
Thank you for this thread, Charlie et al. Hoping that some of you are still following it.
A few questions for KM1700 users:
1. Which output devices was this unit designed for?
2. What is the form factor of caps used in main power supply? (eg, ___D x ___H in mm)
3. Have you encountered any part availability challenges?
4. Is there a reliable set of schematics posted somewhere?
Background info: I use Crest CA-series amps in one of my PA rigs. Happy with their performance, but I need to move away from the model due to part availability issues. Searching for good bang-for-buck in a recent Class H design.
Thanks much...
Brian
Thanks much...
Brian
While the original components of the Crest CA amplifiers might be obsolete, suitable alternatives should be available.
Hi TBTL. Thanks for responding
Any experiences with the KM1700, maintenance wise?
Re Crest CAs: Parts I’m having trouble finding reliable sources for are 105c/10000uF/80-100v/35x50-63mm can caps, and 1302/3281 transistors.
You should be able to use any 35mm 80 to 100 volt capacitor, as high as 71 mm.
See the thread below. if you replace ALL your transistors you can use a suitable replacement.
2SA1302 / 2SC3281 replacement
Use these caps they should be just fine.
1pc Radial Electrolytic Capacitor 80v 10000uf 105C | eBay
The smaller CA’s can use MjL3281/1302. The 18 needs the 4281/4302, which the current production Pro9200 uses. The CA 18 could probably get away with the 21193/4 pair as well, as the original device fT is only 10 MHz. It was a weird type Toshiba only made for a couple of years and quickly went obsolete. I think for a while Fairchild (before the ON acqisition) was making copies but they are now in the wind because the 4282/4302 can replace pretty much any of them.
Any other KM1700 users wanna chime in with issues, mods, etc?
Thanks very much for the tips re output device + PS cap replacements on Crest CAs.
Let's see if there's anyone else interested in discussing KM1700.
Thanks again.
Brian
Thanks again.
Brian
Thanks again.
Brian
can you show any internal photos?
Thanks again.
Brian
The implication is that no Behringer anything can hold a candle to a Crest CA. I have a couple of EP2500’s and they’re no CA12 even though the ratings are close. Anyone seriously looking to replace old bulletproof boat anchors with modern amps would be looking at Labgruppen, Powersoft, Speaker Power, or the like. Amps like the KM or EP need to be used for what they’re designed for and not slamming the limiters for hours or running low impedance loads at high levels. You just can’t make a $2-300 anp do the job of a $2-3000 one.
Luke's basic amplifier tests - Bass Gear - Data-Bass Forums
The Behringer inukes do quite well actually. More power than the tested Labgruppen models here. Nothing compared to speaker power though. There are also some tests of powersoft that show surprisingly low sustained output capability.
If I compare the boat anchor amplifiers I have (Cloud VTX1200) they take up 3u, have very loud fans and manage 600Wrms per channel into 2ohm continuously. While an inuke60000 manages more power, only takes up 2u and has quieter fans.
Funny you say that wg_ski...
My friend hooked up a brand new KM1700 to his Audio Precision test rig last night. Spent 30 mins stress testing and looking at THD+N. First 10 mins with 4ohm load, straight into 20 mins with 8ohm. Used AP’s sine out, feed levels in 22-30v range, sustained tones to start, then slow sweeps. KM sensitivity set to 0.77v, gain control at full to start, half to finish. Measurements made using single channel in stereo mode.
Took about three minutes to get KM1700 warmed up. Fans were at full speed from that point on. I’d characterize fan noise as acceptable for most PA / install scenarios with offstage racking. On a big open bench, casing stayed cool. Despite fact that amp was driven into protection (briefly) every 30 seconds or so.
Keep in mind: Load resistances were bench verified. AP counter accuracy, output quality, test function parameters, etc were not.
Our results showed THD+N increasing with frequency. Meaningful levels starting ~4kHz, a large bump ~7kHz, overall peak ~13kHz, and sustained high levels above.
In either case, derived wattage figures indicated that published THD specs were reached at output powers significantly lower than those advertised.
So, quickie bench test summary:
THD+N @ 8ohm = higher than spec’d
THD+N @ 4ohm = higher than spec’d
Output Power = lower than spec’d
I decided not to pop hood on amp last night. Gonna listen to it a bit today, then decide whether to keep or return. Was hoping to use KM700 on HF and KM1700 on MF in 4way 8ohm/channel PA setup. Currently looking like KMs are wrong fit.
Will post if I come across any surprises.
Brian
Brian
Was that under sine wave or burst testing, and how much lower than specced?
Chris
- Live Sound
- PA Systems
- Opinion on the Behringer KM1700 Class-H amp
