Open baffles & baffle step
Do open baffle exibit baffle step like a normal loudspeaker once the 6dB/octave dipole has been sorted out?
From theory I cant see that they would. As both the front and back are radiating sound then they will both do baffle step at the same frequency. Thus when the front would start to go omni so would the back and reinforce each other. As the back reflection above baffle step would not diffract to the front you would not get any reinforcement at frequencies above this. So thus at frequencies above bafflestep you would hear the front of the driver. But at lower freqs the rear wave would come into play cancelling out baffle step when the front wave starts to go omni.
That seems a little confusing to me and I know what im talking about! sorry for that its hard to explain.
Matt
The quick answer is no, baffle step for an open baffle is different.
Check out http://www.woodartistry.com/linkwitzlab/faq.htm#Q8
When the front wave and back wave meet at the edge, the pressures cancel but the velocities add (sort of). The result is low pressure and high velocity, and hence much diffraction in the midbass region. Higher frequencies are affected but to a lesser extent.
I recommend prototyping rather than simulation (I believe Linkwitz also makes this recommendation).
That didnt really help, I understood what he was saying but it didnt answer my question.
After the response irregularities, ie the 6dB roll off per octave as per dipole radiation, has been eq'd out, do you need to apply baffle step too?
I didnt think you did, but im not entirely sure because in the pheonix he does? cant be sure but I need to know.
cheers Matt
No, it is inappropriate to apply "baffle step compensation" to an open baffle system. And the Phoenix design applies just the opposite of baffle step compensation.
Process: Prototype, measure/listen, compensate/equalize, Prototype, ...
I have learned a bit from my prototyping. I do not have a simple model to predict performance. I follow the above process.
No because baffle step of 6dB is replaced by baffle roll-off of 6dB/octave.
Find it hard to believe a dipole applies 6dB of midrange boost.
🙂 sreten.
Wouldn't that mean that an open baffle has the same initial response roll off as a sealed enclosure? I find that hard to believe as it seems that a sealed merely looses pressure from going from 1/2 space radiation to full space, where as an open baffle has the loss from full out of phase cancellation of the combined front & rear wave to deal with. Also every equivalent comparison I've heard of unequalized open baffle vs. sealed has shown open baffle to be weaker in the bass... open back vs. seal guitar cabs as a simple comparison. What am I missing?
Yes that makes sense - talking to myself. 😀
Right an open baffle would have a flat frequency response if it was not for the rear wave (its more complicated then that but bare with me). I took near field measurements of the W15CY001 in the open baffle and you get a flat smooth response in the mid and bass to about 60hz, then the response falls off rapidly, taking near field ignors the rear wave.
I think that what happens is this. The rear wave and front wave cancel each other out when they meet.
Imagine normal baffle step with its 6dB transition from 2pi into 4pi when bass is omni directional. Because all the sound is produced on the front panel and nowhere else when the sound reaches an appropriete frequency (lowish) is diffracts around the side of the cabinet and we get the loss of 6dB because its diffracting into open air from the baffle so sees the free air as a pressure change, the acoustic impedance decreases so the sound decreases in level.
Now an open baffle does NOT exhibit baffle step at all. Imagine for a second that the rear wave was infact in phase with the front wave. Above baffle step at high frequencies, when you are sitting, listening infront of the speaker you are going to hear only sound from the front wave. This is because the rear wave has not reached an appropriete frequency to diffract to the front.
As the frequency decreases and baffle step is reached normally in a closed baffle the sound creeps behind the cabinet and with it the 6dB fall off. With an open baffle when baffle step is reached or the frequency gets low enough to diffract, the front wave diffracts to the back as per sealed, but this time the rear wave also diffracts to the front. They will do this with roughly equal magnitude. So the loss of the front wave round the back will be equal to the loss of the rear wave round the front,the rear wave will compensate for the front wave loss, thus baffle step would not occur.
But in an open baffle the front wave is not in phase with the rear wave so distructive interference occurs. This gives the 6dB per octave roll off that an open baffle exhibits when baffle step would normally occur in a sealed box. So therefore if you compensate for the 6dB per octave roll off in an open baffle there is no baffle step to worry about.
With regards to the guitar boxes that are closed or open baffle, when open the rear wave at a certain frequency will cancel out the front wave as described so they will sound thinner and less bassey. Because where BS would normall occur in the sealed box and u get the 6db roll off, in an open baffle you get a further 6dB roll off every octave you decrease.
I hope that is clear enough and makes sense.
That makes sense to me but doesn't that contradict your conclusion in your previous paragraph?
For the first half I was describing what would happen if the front wave and rear wave were in phase.
So the diffraction from the rear to the front would be the same as the loss from the front to the rear so no loss in level as frequency decreases would occur. So there is no baffle step.
But in real life they are not in phase they are the opposite so cancel each other out at a rate of 6dB per octave, instead of boost each other as per above.
Once the 6dB per oc is equalised out your back to flat again. Like with the in phase example. My original question was after you have accounted for this 6dB/oc loss do you need to further account for the usual baffle step, and the answer to that is no.
Does that help?
Baffle step causes a 6db step spread over roughly 3 octaves,
thats roughly 2dB per octave centred on the baffle frequency.
Response is flat above and below the step so maximum bass
loss due to the baffle step is 6dB.
Open baffle roll-off is 6dB per octave below the baffle frequency,
the lower you go the more bass you lose very different to BSL.
So you've misinterpreted what I thought I was saying.
And your not missing anything.
🙂 sreten.
Hehe ye i know its not needed thx, I know baffle step and the first octave of dipole 5db drop are not synonomous but they do start at the same frequency, where the soundstarts to diffract. If that brought about any confusion that wasnt the intention.
I am perfectly clear of how it all works must not wonderful at describing it.
🙂 sreten.
Ahhh... but actually I was kinda missing a full understanding of baffle step... namely the step & the 3 octave spread..!
Thanks.
🙂 sreten.
Hi mate, what did you actually mean by BAFFLE FREQUENCY ?
The frequency of baffle effects is directly related to the smallest
dimension of the baffle. for boxes nearly always the width :
f3 = 115 / WB (where WB is the baffle width in meters)
f3 = 380 / WB (where WB is the baffle width in feet)
Here is a sim for a typically medium sized (15"x9") 6.5"/1" 2way :
The 2dB bump at the top is often not correctly accounted for.
rgds, sreten.
rgds, sreten.
Thanks for your answer Sir 🙂 So it means that if I just let a 3 inch speaker play without any enclosure or baffle ... if the width of the speaker is roughly 7cm=0.07m , the 6dB roll off will start at 115/0.07= 1.64 kHz ??
There is something curious though , when the people do measurements for speakers, they measure it alone right ? without any enclosure, and 1m directly in front of the speaker right ?. So it means that if I just create a little frame to mount the speaker, it should reproduce the frequencies just like the speaker graph states, without any problem right ?
Thanks in advance for your help 🙂
no, a speaker is normally measured either on an infinite baffle or on a iec baffle, so with a small frame you're going to get the full baflle step! mount it flush into a wall and you're getting close to the "pretty" graph you see from the manufacturer...
Michael
Michael
Thanks a lot for your answer Michael!! Damn this sucks though lol ,,, and those guys cheat and play with people's feelings 😀
Michael
And it also means that a speaker playing on its own, without being mounted anywhere , has baffle step ... right ?
