What is the wall construction?
If it is plaster board on wooden studs with a cavity it becomes easier. Although not perfect the space in between the studs becomes a sealed box; you just mount a small enclosure on the surface to hold the driver. Mind you the volume is only about 15 litres but can be stuffed to give the equivalent of about 20, a cupboard space on the other side would give plenty of volume
i decided to go with sealed boxes for now guys ... later when i build baffle wall, il just put these boxes in it.
