Open baffle -- some questions
I'm really curious about this for a lot of reasons.
I've seen a number of "audiophile" (hate that word) manufacturers that even have some commercial products.
** do driver manufacturers actually recommend specific drivers for open baffle use? (fostex etc?)
** just to (possibly) build something eventually, can anyone recommend a project that is the best bang for the buck? (or a driver)
I saw a "Tekton design" system that uses an attached subwoofer that looks interesting.
I like low listening levels, which I know is important -- and classical music as well.
I know of VERY few manufacturers who offer specific 'dipole' woofers. aespeakers comes to mind. Some ribbons can be used as dipole drivers. AFAIK Fostex does no specific OB driver. In fact most Fostex drivers urgently need woofer support to work in an OB.
This will very much depend on your musical taste. A 'girl with guitar' OB will cost a lot less than an OB capable of AC/DC.😀
Very small OBs are always suspicious. 🙄
One of those 8'' (or bigger) wide range drivers could do. Wild Burros Betsy or Ciare CH250 perhaps. For some more dollars you get the Visaton B200, Audio Nirvana Super 8/10 or Hemp FR8.
Uses drivers with a Qts of close to 0.7 to 1.0 to help improve the bass response. But that's only at the low end.
You could use a boxed sub for the low end ( below 90 Hz ?). This however will change the 'low end sound'. It will not be exactly the same as a full range OB with say two 15 inchers for the low end. But you can get away with less power requirement at the LF end and a smaller box and a smaller OB baffle dimension.It will still sound good... better than a boxed speaker.
If you search you will find other threads on this and find out that many have reported that using a flange at the ends of a baffle will ( might ? ) affect the imaging and spacious sound that a plain flat baffle can produce.
Only way to find out is to try it yourself !
I've used 12 inch drivers with a Q of just about 0.6 and they sounded great. It still needed a boxed sub to match traditional boxed speakers in the low end. I can't use two 15 inchers per side ! However even without the sub it sounded very good with most music. The OB low end was equalised with a 6dB / octave filter.
Cheers.
PS. A complete answer to your question would be too long to post. It's already been covered in several threads on OB speakers. Spend some time and read them. No single post will be a complete answer but you WILL get to learn a LOT by reading them all! See what others have tried and how it turned out. You have to spend time searching out the information.......there is no easy way out !
You might want to check out MJK's quarter-wave.com site. Martin has done extensive work on OBs. I have built his low-end OB using a Fostex FF85k and an Eminence Alpha 15a which uses a passive XO. My results are on the big thread on that OB. My results can be summed up in one word: WOW. If you like the dipole/bipole type sound, then this may be a good project for you.
Cheers, Jim
If you just want a quick experiment that costs almost nothing just to see if you like OB you could do something like this project my buddy did.
The Smallest OB (amateur audio)
It only goes down to 150 hz and you need a high q driver but it works great, sounds great, and it doesn't get any easier than this. It's a low quality driver and it's a coax (not fullrange) but you can use your choice of high q (over 1 qts) driver. Just make sure to model it first.
I agree on the Betsy's ($100), the Visaton B200's (about $300 but hard to find lately), and the MJK stuff (hoping to build his Goldwood/Jordan JX92S with passive xover next).
My word of advice: if you're doing a single driver on OB, swap out as many amps as you can because the difference in bass results is huge. I found that an SS amp had tremendously more (and tighter) bass than my two small tube amps, but the SS lacked the midrange magic. I'm trying two more tube amps in the coming weeks in an attempt to get strong bass /and/ the midrange magic (the Miniwatt and a 35-watt Bada hybrid).
... swap out as many amps as you can because the difference in bass results is huge...
like, as in, ck output impedance, and feedback, and how they relate to damping?
it makes even more difference when a driver is used in a speaker without much load on the cone?
In other words, a high feedback, low output impedance, SS amp might help compensate, and be needed to bring the bass up?
Better than acoustic loading?
if you like classical, you'll be amazed at how closer you can get to feeling a piano with OB speakers... on the other hand a single driver will struggle with big orchestral pieces, going with an helper woofer will really free them up...
i think that betsy+boomer (you can find it on this forum) is well worth a look given you are in the usa, you can always start just with the betsy and then consider to upgrade
I need to find some woofers that will work -- have some nice vifa tweeters that sound great with just a simple 1st order capacitor xover -- and some walnut plywood in the shop.
Also already have a subwoofer ready to go.
Anxious to hear what an OB sounds like.
Remember when I was a kid I actually had some OB spkrs and didn't know it. Dad gave me the fronts of his late 50's "hi fi" speakers -- JBL D123's and EV T35 tweeters !
I set them up in my room without an enclosure until I finally built some.
Actually the box I'm thinking of taking my parts out of (some old junk speakers) have the VIFA tweeters and some 8" Goldwood woofers. QTS is exactly .70 on the woofers.
Think I'll play with that.
What is the rule of them for how large the baffle needs to be?
Distance to wall etc?
It's a small room and like I say, I like low volume so this may work out.
it makes even more difference when a driver is used in a speaker without much load on the cone? In other words, a high feedback, low output impedance, SS amp might help compensate, and be needed to bring the bass up?
Hi Serenechaos, yes indeed! I only wish you got to hear the SS amp but I hope you will next Sunday, Dec. 13? Upright bass is really strong. Will have the BiB's working by then as well. 🙂 And I should have at least one more amp to try (the Miniwatt).
Regardless of baffle size you won't get any real bass out of those drivers.
Wow...
Ok; I prefer acoustic loading (the horn), and a tube amp.
Some do prefer SS amps & less efficient speakers though.
Yes, looking forward to next Sunday!
Been listening to Bach this afternoon, getting ready to switch it up to Miles soon.
Rotating out from the BVRs, Swans, & Austins.
FINALY figured out how to make the BVRs sound decent...
Sorry Serenechaos, I meant that yes, I was using SS to bring the bass up. But no, I didn't mean to say that was better than a proper horn. I know I will have proper horns eventually, I'm just clawing my way up the evolutionary ladder. (I'm actually recapping my Klipsch Heresy's, oddly enough.)
