OPAMP VU Meter Buffer
Hello all,
I have an amp I want to add a VU meter to. In the interest of keeping my sound as clean as possible I decided I needed a buffer circuit, I have come across this circuit but I need some help understanding how it works. The design I had originally came up with on my own did not have 90% of what this design has, and I am curious why.
Thanks,
JD
the op amp is powered from a single supply. To bias the opamp properly the inputs have to be at 1/2 VCC thats what the power supply does. The opamp has balanced inputs to connect to a balanced preamp or a bridged poweramp. The output of the opamp is AC coupled and the output positive or negative peaks are rectified and connected to the meter. There is a peak detector to tell you when you have reached a certain level or clipping occurs. Leds are faster that an averaging meter movement.
So the 47k is for the balanced input spec? Or is it just to keep from loading the circuit? What if I wanted to use this on say, the output of a tube amplifer? That wouldnt be bridged outputs, so Im not really sure how to deal with that. Also the caps on the inputs are for the AC coupling then right?
