opamp input based power amps
i remember i found few years ago some amplifiers that have inputs based on opamp's .....also some of the opamps were bootstrapped to increase the voltage swing....
does anyone have high quality schematics of power amplifiers that have opamp in the input - preferably bootstrapped and they could have mosfets or bjt at the output doesn't matter....power needed 50-100W /8ohm....
regards
daniel
Thought this may be of interest.
jerlwoo, you don't need to bring the center line back to the drivers. as a matter of fact, with the center line going back to the drivers, should you ever blow the amp up, guarantees the damage will include the drivers and VAS....
also.... is there any bias on this amp?
op amps make great input stages, as long as most of your voltage amplification comes later.... i like jerlwoo's op amp to VAS transition using common base.....
