OPA627/AD8610 comparison
changed my DAC(Elektor2000) analog output chips from OPA627 to AD8610. There are 4 of them 2 for the I/U conversion and 2 for the filter. Ok the AD8610 sounds bright. Sometimes a bit too bright. The Sssss sounds are not so nice as on the OPA627. Tried different speakers and the symtom stays. Amps are 2xUCD400 with AD8620's and a passive preamp. Dac unit is snubberized.
Anyone has the same experience?
hmmmmm
Everything is so dependant on outside factors, but actrually I have noticed exactly the opposite.
I actually prefer the 8610/20 as much warmer less sybilant than the 627/637.
And now I am trying the LT1115(low voltage noise) and LT1028(low current noise) both with great success. So much so that I find it equal to the 8620 on everything I have listened to so far. 🙂
Also I can state that the LT1010 seems to be at least as good as the buf634, especially when fully biased.
15V is above the max on the 8610/20 datasheet. In my tests this opamp sounds best between +/-10V and +/-12V above that and it gets nasty. For kicks I even tested it down to +/-5V and it still sounded great.
Above 12V the 627/637 are definately better. I still am not convinced the 627/637 are any better than the LT1115. But they are indeed much better than the opa227/228.
