Are there any good alternatives for the OPA290 opamp? I need the single 8-pin soic version.
Regards, Gerrit
Regards, Gerrit
OPA290 is a micropower opamp .
OPA 134 certainly is not.
It depends on what you're looking for.
Start looking at texas inst : https://www.ti.com/amplifier-circuit/op-amps/overview.html
Rick,
My circuit needs an OPA290. My supplier doesn’t have them, so I need an alternative.
I’m lost as I have no idea how to compare opamps.
Regards, Gerrit
Regards, Gerrit
Maybe another supplier ?
https://www.ti.com/product/OPA209?
https://www.mouser.com/c/?q=OPA209
Any other opamp we may suggest here , is likely not in stock at your supplier too.
For suggesting an alternative , you need to know what it is used for.
Similar products you might be interested in
open-in-new
Compare alternates
Drop-in replacement with upgraded functionality to the compared device
OPA210
2.2-nV/√Hz, low-power, 36-V operational amplifier
ACTIVE
Higher performance device with super beta inputs and lower current noise
The OPA210 is not available either. I'm shopping at conrad.nl.
Mouser will charge 28 euro extra for shipment. Rediculess.
What a mess.
Regards, Gerrit
What a mess.
Regards, Gerrit
- Design & Build
- Parts
- OPA290 alternatives?
