OPA2134 Drop-in replacement
Chris -- have a search around for PMA's comparison of a bunch of different opamps new and old to give you a better appreciation of what you're gaining (or not!).
Also worth minding whether multiple feedback or Sallen-Key configuration is better for your setup. (There's a good application note by Bonnie Baker about that)
Hi Daniel,
Yes, the LM318 is still useful, but it requires more care in layout as it will oscillate. You and I probably don't have a problem with this because of experience, but someone new really might have trouble with it.
Bonnie is a great author. Love her stuff. I have very likely read that app note.
-Chris
Not so, the filter is all designed around low impedance circuitry. If you were dealing with 10 or 100meg resistors in the networks then it would be a totally different story, this is definitely all low impedance stuff.
Yes, JFET devices make a good choice, but not for those reasons in an application like this.
Hi Daniel,
You're probably right.
Hi ticknpop,
Impedance is a relative thing. BJT input op amps can represent a high input impedance. It's just that a J-FET op amp has lower noise at the higher impedances as a general rule. If memory serves, the LM308 was a very high input impedance op amp that had a BJT front end.
As Mooly pointed out, filters can be designed as a low impedance filter (think speaker crossover for an extreme).
-Chris
LME49860NA is SOIC package so I'm just wondering instead of putting it into a socket I'd just solder it on the other side of the PCB. May have to bend the pins a little backwards. But will be neat.
SO8 pins don't bend. They're very tiny, and you'll shear them off. It might work with some jumper wire, but it'll be a real PITA.
TI sells a nice set of adapter boards for very low cost that allow you to use a number of SMD packages in 0.1" through-hole circuits. Search for DIP-ADAPTER-EVM and you'll find it at the TI store as well as at a number of distributors. You get 6 each of 6 different SMD packages, up to 8 pins each. Here's their description: DIP-ADAPTER-EVM DIP Adapter Evaluation Module | TI.com The kit comes with header pins too, so all you need are the ICs and solder.
