If you want something simple, use a LH0033 Sziklai.
http://audioportal.hi-fi.ru/showthread.php/51629-Рижский-буфер-3
http://www.diyaudio.com/forums/head...portable-headphone-amplifier.html#post4760389
Patrick
Patrick
Ðèæñêèé áóôåð-3.
Patrick
It's more complicated than op-amp+one transistor.
I will use BD139 or something better, bias it using LM317 to around 500mA, throw in huge heatsink and this should suffice. I just can't think of something simpler (like I said before - I need to use ADA46x7-1 in this one, I just can't let this chip sits on the shelf).
I wouldn't let it sit on the shelf either.
Never tried the '4637, but I think the '4627 is a very good sounding op-amp.
Ah, that's along the lines of what I was talking about earlier.Let's look at Douglas Self design from "Small Signal Audio Design" (I hope It's ok to put it here):
(Depending on opamp, a series resistor between opamp output and buffer input may be needed. The one used here has several hundred ohms already built-in, in some other cases an external 47-100 may prove helpful. Reserving a spot for a double-digit pF capacitor from opamp output to inverting output is also advisable.)
Not likely. Most of that actually ought to be coming from the TL072 if you compare his opamp measurements. A well-biased buffer tends to perform extremely well.An externally hosted image should be here but it was not working when we last tested it.
Is this really that bad thd? Can You hear 0.01% distortions?
Actually there isn't too much wrong with an EF + CCS buffer. I think it was our Bonsai who suggested (and simulated / measured) such a circuit here. Efficiency is not exactly its strength though - you'll need twice the bias current of the equivalent push-pull Class A stage, so it wouldn't be unusual to see 150 mA of quiescent current here, with heatsinking to match (that's a few watts to dissipate there).I'm still leaning to one NPN inside the feedback loop, biased to class A using a simple resistor, or even simple CCS made from voltage regulator.
Note that an LM317 CCS will appreciate some series resistance when more than a few volts are dropping over it, otherwise it may oscillate. EFs also tend to be more finicky with capacitive loading than MOSFET followers (ever wonder why a Szekeres is a DIY classic while there are hardly any similar projects involving BJTs?).
As you can probably tell, even a simple circuit tends to require some extra measures to make it work well in real life.
I always use resistors on op-amp input/outputs and transistor base.
Can You say something more about that LM317 CCS configuration? Maybe use something like this:
(source of image: https://vwws.wordpress.com/2011/06/21/dn2540-lm317-cascode-ccs/)
