Op Amp voltage follower settling time
Good day, all
I have designed a 2 stage differential input and differential output op-amp with gain close to 45dB and phase margin of 60 degrees. I am trying to connect it as voltage follower based on Op Amp Voltage Follower Uses to check its response for a step input. I am connecting a large resistor between the (+)input and (-)output and vice versa. With VDD = 0.9V and VSS = -0.9V, and differential input 200mV, I am expecting the same differential output voltage.
However, I get an amplified output voltage (Almost -0.8V to +0.8V). I checked that the op-amp is not getting saturated. What am I missing? I want to check what time the output takes to settle.
Any ideas? Thanks a lot!
Good day, all
It should work if you use a series resistor at each input (say a few k) and connect the inputs and outputs as you show but instead of 100Meg use much smaller like 100 ohms.
Jan
Thanks again!
Here I cannot short the input to output directly in case of differential input and differential output amplifier right? Usually the gain of fully differential amplifiers is determined by the (two identical) input resistors Rg and the (two identical) feedback resistors Rf. A = Rf/Rg.
Without Rg (in schematic) gain can not be determined.
