op-amp + op-amp buffer combinations
Assuming the buffer is faster and that this will be used as the power amp for driving speakers,
if you have a op-amp with good THD+N performance and one with bad, in addition to a buffer that has good and one with bad, and you put the buffer inside the feedback loop of the op-amp, what will the THD+N of the combination be like for the different combinations:
good op-amp + good buffer
good op-amp + bad buffer
bad op-amp + good buffer
bad op-amp + bad buffer
Has anyone tried this before?
