oo and how do you charge cap, that is in high side of IR?
With costant voltage and his reference connected to drain of mosfets?
That capacitor charges through D1 and /inrush current limiting/ R28.
The cap is connected to the source of the high-side mosfets.
oops my mistake, I ment source.
Ok I see how you got it.
I will have to check at home how I have done this.
While I think now I think I have made it too complicadet
I need the PWM signal, coming from the TL494, and the inverse of the signal. TL494 cannot make the inverse of the signal, that I need.
I can invert the PWM with a single transistor, like a BCxxx, or with a TTL/CMOS inverter, or I can connect the TL494's transistor's in the way, you can see on the schematic.
When I use TL494 in push-pull mode ( OUTC tied to VREF ) then both the outputs will have the same duty cycle. For example 30% 30%, but I need to drive the high-side MOSFET with 30% Duty-cycle, and 70% duty-cycle, the lower MOSFET.
That is lower efficiency, less complication, less fun, but since this is not for me and I don't have 5 years to make it, it will have to do 🙂
I was experimenting a little bit in my simulator.
I created a schematic, wich makes about 750nanosec dead-time.
Is that too much? Or too short?
T1 transistor is the TL494's output transistor. I applied 50% duty-cycle square-wave to the transistor.
On the schematic there is CD4069, becouse the simulator haven't got CD4049 in it's library. I'm going to use CD4049.
What do you think of this? Will it work in the real world? 🙂
I have /now/ a few experiences. The efficiency is very low (about 70%) at 20A output current, becouse the U_in is far more higher than U_out, and /becouse of this/ the switching losses are dominating, not the ohmic (RDS_on) losses.
I couldn't decrease the switching frequency, becouse then I would need a huuuuge output inductor. The core is quite big, about 4cm outer diameter, and 2cm inner diameter. Only 4 turns are on the inductor, and I think it still saturates, when I go over 20A. I can't decrease the turns on the inductor, becouse then the dI would be too high. Now (with 4 turns) the core is very hot even if I use active cooling, with a small 486 CPU fan.
I will try to get/make an inductor core, wich can "hold" more energy.
Hi danko
How is the project coming along. If not to good there is a thing you can do/think about it.You and I try to drive N-channel mosfet with IRxxxx, trying to drive its gate over the input(max circuit voltage). But there is much simpler way. Use P-channel mosfet and you dont even need IR, the PWM chip can drive it directly.
What do you think?
What do you think?
- Power Supplies
- oops!!
