Onkyo Integra 8067 blowing fuses
tgferg67
2006-09-21 5:36 am
I am open to suggestions.
I have an Onkyo Integra 8067 integrated amplifier from the
mid 80's that is blowing the main fuse every 5 minutes - no speakers conncted and volume down. The right channel power transistors are hot to the touch, while the left are pefectly cool by the time the fuse blows. I unsoldered the right channel power transistors and the fuse does not blow when the amp is turn on. The right channel power transistors still check out ok with diode check on the multimeter. All the power transistors on the driver board check out also.
About a year(500 hours) ago a similar situation with blowing fuses - the right channel power transistors were shorted so I replaced all and everything seemed well so I also recapped and adjusted bias.
Photo of power supply/driver boards
[IMGDEAD]https://img.photobucket.com/albums/v447/tgferg67/onkyo-800x600.jpg[/IMGDEAD]
