Hi all,
I'm gearing up to build some dmar-ken7.3's and I'm struggling to find a supplier for speaker lining here in the uk.
So far, I've found some 10mm sound absorbent felt available in 1700gms and 1100gms weights but nothing thicker.
Loudspeaker damping materials for DIY speaker kits.
3rd item down.
Are there any UK user whom know of anything more suitable in the UK or, something good that can be re-purposed for use in speakers. Alternatively, If there is a supplier in any other countries that will ship to the UK then please point me towards them!
Thanks all
Gavin
3rd item down.
Thanks all
Gavin
The 10mm stuff should work fine. I will go down later today, weigh and calculate the density of the stuff we use to help you choose between the 2 available.
dave
dave
Seems your stuff is about 2 x as dense as what we use... you may need to add some light fluff as well
dave
dave
Hey,
Thanks for taking a look for me. If its twice as dense then that sounds to me that using this could be too big a risk considering the effort to make it.
Can you point me towards the places you get your choice of lining from please?
Are these any good?
Woollen felt rolls and synthetic felt rolls or sheets in all densities
The above company can make felt to order so, if you could kindly let me know what weight material it was that you guys use I could contact them for availablity for a near match I hope.
The lining we use is UltraTouch. Really only available in North America. Before that we used a somewhat similar felted cotton we recycled out of old spealer boxes.
You should be fine with the thicker version of the stuff you linked. The stuff in the 2nd link looks better, and is available in lots of desities (not that i know what an sg is)
dave
dave
Mudchute, hope it is not to late, I found something probably similar to the Ultratouch at this link. It is 20mm thick and 1200gms. The site is in French and the English version does not look too good. However you may try to look at stores in the UK selling stuff for insulating vehicles.
I wonder if it is not worth peeling off some of its thickness off before glueing...
- More Vendors...
- Planet 10 hifi
- Onken lining choices.
