Onix & soap needs a re-cap
Hello,
I own a amplifier and power supply that is based on Naim audio's Nait 1 integrated amp. They are both due for a re-cap but i don't know what capaciters to use. Here is a discription of whats inside. Onix
I have found 40v 22000uf Phillips caps that would fit the power supply but don't know which ones to use. I have also found 63v 4700uf panasonic caps that would fit the amp but don't know if they are any good.
So far i've looked at the Rs catalogue, Farnell, Kendeil and Audiocom but find all the different cap specifications a bit confusing
Hello,
Hi Fatmarley
My name is Tony Brady and along with Craig Hill, formed Onix Audio in the late 1970's to initially build MC head amplifiers and then went on to build the first OA20 integrated amplifiers in early 1981 (I'm sorry I don't remember the exact date - many years have passed)
First of all I'd like to correct your ascertion that the Onix Integrated amplifer is based on the Naim Nait1 - it is not. Actually the Nait came out about 1983 IIRC. The OA20 and the OA21 which replaced it in jan 1982 featured a differential VAS with current mirror load which was inspired by a Hitachi application note for MOSFET power transistors! The input stage was a differential with a constant current source. The output stage was fully complementary.
anyway back to your question:
I presume that you have an OA21 as you have the external (SOAP 1?) power supply. Later versions ( OA21S) were fitted with custom made BHC capacitors in the power supply, 4700uF 63V diameter 25mm and 40mm high, the highest that you will be able to fit to the pcb will be 50mm. The pitch for the pins is 10mm if your amp is fitted with these and they are not leaking then I wouldn't bother to change them as the Panasonics are likely to sound worse...Kendiel I haven't tried so cannot comment on the sound but as long as the can size is ok then the spec to look at is the ripple current - anything over 2 Amps each will be ok. You can safely fit 50V caps as well...be careful to observe correct polarity as the pcb isn't marked.
where you will be able to make a good improvement is in the external power supply. Later SOAP 2 supplies were fitted with BHC 15000uF 63V caps, these again were custom parts with screw terminals. The Kendiels have a good reputation so may be worth a try here.
I hope that this has been of some help to you
Tony
Tony
Thank's Tony,
I will phone a Kendiel distributer tomorow and order some caps.
On the link i left a guy suggested that i replace the volume pot to a panasonic one.
Are they a standard fit?
Also is there anything else that may need replacing or would benefit from being replaced?
Cheers
Matt
Cheers
Matt
Hi Matt
the panasonic pot is not quite a standard fit - you will need to drill out the mounting hole to 9mm.
I saw your question about using ALW's super reg on the pfm forum but this would only improve the phono stage if you are using it. The OA21S (and OA21E) has no pre-amp stage - just the passive 10K log pot straight into the power amp section.
Does the amp have 1 relay or 3 under the phono board? if they are not red in colour (NEC MR62) then it is definitely worth changing to NEC type...If there is 1 relay the amp is a 21S and if there are 3 relays it is a 21E. The S is the better version to have as it has no speaker fuses, if it is the E version then change the speaker fuses to new F3.15A fast blow and tighten up the fuse holders, I don't recommend shorting out the fuses in case of disasters!
You might want to change the wire to the volume control while you're at it and solder directly to the pcb pins if a connector is fitted - twist the wires in the same way as original i.e. separate left and right channels.
It could be worth tightening the bolts fixing the output transistors to the heatsink, but don't go too mad or the bolts will break.
ciao
Tony
ciao
Tony
Thanks again Tony,
I must have the E type because i can remember seeing 3 fuses inside the case, 2 were near the speaker sockets.
I will double check to see if they are red before puchasing a new relay.
Do you know where i can get an (NEC MR62)?
If it sounds like i don't know what i'm talking about it's because i don't but don't worry i'm not going to do the work myself, i hear capaciters have a nasty habit of blowing up if you fit them the wrong way round.
I'm glad you advised me not to do away with the fuses because the thought did enter my mind.
Sorry if i'm being a bit personal but what happened to Onix Audio?
Matt
Matt
Hi Matt
the third fuse under the red cover is the mains fuse, value T2.5A obviously disconnect the power cord before this point! again tighten up the fuse holder.
the MR62 relay you can get from Farnell 309-2860, you'll need 3 off.
to cut a very long story short Onix, which was already partly far eastern owned was sold fully to them in 1996, this was the end of my involvement so amplifiers such as A60, 120 are nothing to do with me...
good luck with the re-build!
cheers
Tony
cheers
Tony
Would be great if anyone can help
I have a poorly oa21e with blown output transistors on one channel and intend to replace these with mj15003/4 pairs. can anyone tell me what the required bias setting should be and where to measure it? Is there a schematic available?
Also, if anyone has any spare BC416C's please let me know.
Cheers
Cheers
Just found this
I took a chance on an ONIX OA20/2 for parts or repair on ebay. The seller did not know its problems. I have always wanted a brittish integrated, so I bit on the auction.
I got it for a pretty low price and I am hoping to be able to resurrect it. It won't be a great loss if I cannot.
Does anyone know the speaker fuse values? Is there a place where I might get a manual or schematic?
I am not too hopeful for for much help considering the age of this unit, but if anyone is out there that can help I would greatly appreciate it.
Many thanks in advance.
Leonard
Leonard
hey! its great to see tony brady on the forum!
i've heard so much bout onix but i haven't seen them here in singapore..
is there any chance i can get hold of a set of the schematics?
Onix OA20/2
Hi
I own an Onix OA20/2 which I bought in the 80's. It still works fine and I use it every day. But, tonight the changer knob came off in my hand and I can't get it back on! The fixer screw buried deep in the big black disc doesn't look like a normal screw head ... I don't want to apply force. Does anyone know how to get that knob back on?
Many thanks
JohnE
Hi
Many thanks
JohnE
Its a little allen bolt, get a key-set from the local hardware store. careful they are quite delicate
onix oa21s right channel blown
My onix oa21s has blown its right channel after my dog wiggled behind my right speakers, causing the speaker cable to come lose and short itself. Tony Brady, are you out there? Is anyone able to help? The SOAP2 was connected when that happen.
Hi, I had a similar issue with my OA21 about 6 months ago. I'd desolder all the transistors on the affected channel and test them to see if dead. Also check all the resistor values and compare with the other channel - a few of mine had gone off. The big 0.22R resistors were also fried. I'd recommend replacing like for like in both channels as when i did mine there was an audible difference between channels.
Hope you get it sorted
Hi Spev, so you sorted it out? That is encouraging to hear. I really do like this amp a lot. The other day, I took it apart thinking some of the solder might be loose, but all was intact so I believe some of the components have fried. The worse is there is still sound coming from it, albeit not as loud as before. Could it be possible that the capacitors are affected? Also, I thought the OA-21s has some sort of circuit protection.
This is just too spooky. I sold my onix a month ago (knew I never should have) and it arrived damaged. The chap took it to a "repair" guy friend to take a look at, whose, to cut a long story short, "attention" has now blown the amp again. So it is back with me for repair. I'm, out of pocket for 2 lots of DHL and have to find the time to repair the amp. Oh, and yes, I have to refund the buyer.
The 21s does have output protection - it's different to mine so I can't really predict what's happened to be honest. Either way, there ain't much in there so it's easily rebuilt from scratch.
What CAPs would you use if you were to replace them? I am not an electronics person, but I want to learn more about my own OA21S.
Thank you
David
Thank you
David
For info on cap choices, go to www.pinkfishmedia.net (DIY room) and search for posts made by James evans and me.
hudsy said:What CAPs would you use if you were to replace them? I am not an electronics person, but I want to learn more about my own OA21S.
Thank you
David
All depends which caps you're replacing. The large psu ones can be a swine as they are 25mm dia - most current decent caps of that uf size are 30mm. You can get them to fit by bending the cap pins, but it's very tight. Panasonic TSHA would probably fit in ok and be reasonable replacements.
Input coupling and feedback caps I have elna starget at the moment and they sound pretty good in this amp. PSU decoupling at the input relay(s) and on the phono stage I've used panasonic fc. Output coupling on the phono I used elna starget again, and replaced the input tants with fresh ones. Voltage regulation caps (phono stage again) I replaced with panasonic fm. Mostly all of the above is what I have lieing around in the bits box. If you're intending swapping caps around and testing different ones in critical areas such as input coupling and feedback then I'd fit flying leads through the pcb so you can just solder and desolder the caps from the leads.
Good luck with any changes, they're lovely amps. Got to start debugging and fixing mine soon 🙁
James
- Design & Build
- Parts
- Onix & soap needs a re-cap
