oneplustwo F5 build thread
Made some progress today and just wanted to double check a couple things with you all.
  1. From the transformer, blues and greens (Antek) go to the same tabs on the rectifiers.
  2. Then the + output of the rectifiers go to the + tabs of the caps (with the other tabs going to the minus tabs of the caps of course).
  3. Then one + cap tab connects to the umbilical tab as the +, and one - cap tab connects to the umbilical tab as the -.
  4. The remaining + and - are connected together and go to the umbilical as the ground.
  5. That same ground is connected to the chassis and earth ground via a thermistor.
  6. I also use the terminal blocks and thermistors and C9 in this enclosure (not the amp enclosure)
(CAPS ARE BACKWARDS IN PHOTOS)
Connections from transformer to rectifiers to caps:
Minus/Ground/Plus from left to right along the bottom:
These connect to the umbilical jack (in my case, a neutrik 4-pole).
I'm going to route the primary wires below the aluminum plate for the terminal blocks, thermistors, and such. The IEC will be located below the plate as well.
Hope that makes sense! Please let me know if anything isn't clear and if everything is ok otherwise!
Thanks!
I would start by connecting the safety earth to the psu chassis and running a wire attached to that point, through the umbillical and then on to the amp chassis. The audio ground should attach to the safety earth in the amp chassis through the CL-60.
Float all your connections/connectors/jacks off the chassis except for the safety earth.
The ripple is proportional to the current demand.
No current demand = no ripple.
Tiny bit of electrolytic leakage current = tiny bit of ripple.
Bigger level of ClassAB quiescent current = bigger ripple.
Large amount of ClassA quiescent current = large ripple.
Hum signal down around 0.3mVpp will be in noise.
That equates to roughly 0.1mVac of 50/60Hz hum.
I can't see hum at that level on my 2mV/div scope.
At double that level I would just be able to see the slow moving waveform in the picturewhole noise, but the signal is too low for the scope to lock on and allow me to see the hum signal.
Made some more progress and will have pics ths weekend. In the meantime, any recos on a cheap but good computer fan? Thinking about building a "fan base" as someone had suggested earlier and wanted a reco on a quiet fan. This one seems good: http://www.amazon.com/Cooler-Master-Computer-Cooling-R4-LUS-07AR-GP/dp/B002LE8BJA
Not cheap, but hoping the large size means I can run it slowly and keep it quiet but still move a good amount of air. Maybe get a pot to control speed.
Thoughts?
enclosure progress
Here's the PSU enclosure. It's a basic square cross section box with mitered construction:
The front beveled panel is some left over African Mahogany from my Zaph SR-71 build:
Here, you can better see the top and bottom vent holes which I planned to match the middle one which is where the 1/4" aluminum plate that everything is mounted to will sit. Matching slots on the rear.
And here's the rear which will be screwed in place:
The IEC hole is a bit shoddy which I'm not happy about, but oh well.
Carried through the theme to the amp with African mahogany on the front and plywood on the rear again:
View of the bottom and front:
View of the bottom and rear:
I cut a piece of plexiglass for the top and it will screw in place on top of the heat sink.
