One or two separate transformers?
I know this issue must have been discussed to its maximum, and I ask anyone that may guide me through this forum in order to find the answer for this question:
What is the difference/what are the advantages of using separate transformers for a two-channel amp, or even a single transformer with two separate windings, in comparison with a single, one-winding unit (that could even feed dual separate supplies, starting in the bridge)?
So, there are many possibilities, and I would like to acquire more info about each one.
Thanks for all inputs, or links to previous threads about this matter.
I think has it correct on this issue. A well designed amp will avoid cross talk due to common impedance or inductive cross coupling. In terms of dealing with PSU ripple arising from cross modulation between the channels modulation, this is entirely a matter around the inherent PSSR of the amplifiers.
