Gents:
I have a Parasound HCA-1000A that I have been using primarily as a rare chan amp in my HT rig for the past 5+ years. The fronts are driven by Parasound 1206. I am pretty happy with the sound. Much better than the Adcom amps they replaced.
I recently pulled the HCA1000A out of my HT system to drive a pair of Altec 846Bs. Last night, after extensive listening, one channel completely ceased to work. I get complete silence.
The costs of this amp is such that it does not make sense to send it for repairs. I want to try fixing it myself. Is there a "typical" failure mode to amp that I can try to shoot in the dark to replace? I have no schematics to work with. Fixing this myself will be a challenge.
Can someone offer any suggestions and help?
Thanks.
Thanks.
You have to give more information, before we can help. Did it smoke? What about fuses?
Connections OK, DC offset?
Parasound HCA1000A - one channel dead
John:
Thanks for responding.
I was not in the room at the time, so I can't attest to smoke/no-smoke question.
The other channel sounds fine. SO the AC fuse is good. I assume the PS is good.
The speakers work fine. Nothing was blown.
I do not know if the speakers are fused or not. I can put a DMM on the output terminals and measure the DC voltage level. How much am I expected to read?
I have not taken the cover off yet. Put when I do, I will look for burned parts. I am hoping the power trans are not blown.....
ANyone with a schematic for this that they can share?
Kwing
John:
Kwing
