One B+ for the both driver and output tube if they are identical?
Probably no disadvantage, even if you don't decouple the HT between the stages. However, with more then two stages there is a risk of positive feedback between the 1st and 3rd stages, which can lead to LF instability (motorboating). It's normal practice to decouple the HT for every stage.
I seem to remember reading that capacitance in uF x resistance in ohms/1,000,000 should be 0.1 or greater, for good decoupling.
So, from this rule of thumb, if you want a small voltage drop and use e.g. a 470 ohms resistor, the minimum capacitance you need = 1,000,000x 0.1/470 = approx. 220uF.
