Its been just under a year with no problems at all.. Then last night I fired up my system to let a friend listen and it stared on the left/mid channel only 🙁
Did anyone ever conclusivle prove what was causing the problem???
I guess I'll have to call Behringer's tech support.
--Chris
--Chris
Several of us have had problems with the ribbon cables
coming loose.
I believe you can open the case, and just re-seat each
ribbon connector.
Search on an identical thread and you'l find posts by
myself and thylanter on this topic...
Good Luck!
coming loose.
ribbon connector.
Good Luck!
My solution has been to just leave the darn thing on all the time.
It's nice and quiet and has been on for months.
When I turn it off, the likelihood of the noise occurring in the first 24Hrs is large. But after that, it settles down.
It probably is some loose connector or solder joint that when warm forms a good connection, but when cold is 'noisy'.
Several fixes have been described. But a simple 'leave it on' is worth a try as well.
Mines just started frying eggs. 🙁
I've put some gaffer tape under the XLR's, and also taped down the ribbon cable... Is there anything else I can try while I've still got it all in bits or have I covered all the bases?
