I've got an old passive Jamo A 210 SUB from with 2x 8" Drivers.
I don't know much about the SUB but here are some specs i found trough Google:
Power: 2x100W (2x150W peak)
Sensitivity: 90 dB/1W/1m
Frequency: 30 - 200 Hz
Impedance: 8 ohms
What plate amp would you suggest for this subwoofer conversion ?
Or is this a deadbeat SUB and i should just buy an active one ?
Here are some pictures of the subwoofer itself:
Outside:
http://193.238.185.184/images/2626808?size=original&index=2
http://193.238.185.184/images/2626808?size=original&index=3
Inside:
http://s12.postimage.org/hqjne64jh/20130215_133728.jpg
Regards,
John
Impedance: 8 ohms
Outside:
Inside:
Regards,
John
i think that with this one you will be fine
Yung SD200-6 200W Class D Subwoofer Amp Module w/6dB@35Hz 301-506
but what about the satellites.. do you have an amp for them ?
or you just want to use the sub as it is,, no satellites , like to add bottom end to a tv
ahhh now oc your configuration,
the sib bux have the high pass filters inside, to drive the little satellites
well, you will need a 3 ch plate amp to drive the sub and satellites then
or what is your plan
Explain better what you want to do
also this is a nice 3 ch budget amp that dont break the bank and is class D
but. you will need to get a 12v power supply for it is a car amp
http://www.onlinecarstereo.com/CarA...mpaign=pricegrabber_shopping_Price_Comparison
Thanks for the reply maxo,
sorry i didn't make it clear how the setup is going to be.
I will not be using the satellites with the subwoofer, my setup is:
AVR: Yamaha RX-V 773
Front Speakers: Yamaha NS-777
Center Channel: Yamaha NS-C444
Back / Surround: N/A (will buy this year)
So basicly i just want the convert that subwoofer from passive to active to plug it into my subwoofer slot on the receiver.
These NS-777 floorstanding speakers pack a punch bass wise when listening to music but i'm lacking bass in the movie watching department
Hope this clears it up!
Thank you again maxo!
You think this is enough to power 2x 100/150w subwoofer speakers ?
The wiring on this amp is just single - and single +, how would i go about connecting the two speakers to the amp without blowing things up
Specs of the subwoofer speakers:
Impedance: 8 ohms
-John
