Dear DIYers,
Here is a schematic I've found on russian sites about a Headphone Amplifier based on old tda2003. It works on 12 v and Thd levels claimed to be below %0.006. I tried to design a PCB for the unit. I also added a LM317 reg stage as a better PSU. I fixed the voltage on 11.5 volts.
Here is the schematic and test pcb files. Would you please kindly comment on the PCB? If no problems mentioned I'll build one.
Thanks.
Thanks.
