Guys,
Found an old (early 50s?) 'Cinevox" Projector amp on the side of the road, nothing useful except the transformers & valve sockets.
The OPT measures 400 + 400 ohms primary, and 56 Ohms secondary. The Primary seems ball park, but the secondary seems too high for normal speaker loads. Comparable tramsformers I have for 15 ohm speakers measure 2-3 ohms.
My guess is that this is for some sort of Higher Z load?
Cross section area of core is about 1" sq - can probably handle about 10W?
Any alternative theories?
Pete McK
Pete McK
"could be 70.7 volts output for long cable runs....."
Perhaps but isn't the transformer rather small?
tube
The only tube left in it had the part code partly scratched out, but I think it's a 6C5 or 6L5, has a metal can; there are 7 octal sockets, in a layout which is really bad for heat dissipation.
There is also a power transformer and a large choke. The build quality isn't very good.
"could be 70.7 volts output for long cable runs" - I'm thinking it's for something like this, 10 W was a lot of power back in 1950!!!
Perhaps I should think about using this transformer for inter-stage use?
Thanks for the input,
Pete McK
Pete McK
