Hello All,
Been diying loudspeakers, doing novice electronic repair and dreaming about the perfect system for 30 years.
Currently working on a poor man's version of the Infinity IRS, except mine will use DSP and be tri-amplified via class-D, approx 2000 watts per channel. Then all I need to do is decide on sources. Probably use the DSP as a pre-amp. Not sure if I want to go all digital or add a 'table.
