Hi all,
Have just bought a Peavey XR684 powered mixer and am slightly (only slightly!) confused over the speaker ohmage limitations.
Heres the manual:
http://assets.peavey.com/literature/manuals/xr684_684plus.pdf
SO....taking into account I'll NEVER use the bridge output....can I have 4 speakers ( 2 either side ) @ 4 ohms each to get max power?? ....
OR...4 speakers ( 2 either side) @ 8 ohms each?
Slightly confusing...or is it just me?
Ta in advance, Si
Heres the manual:
Ta in advance, Si
It is rated down to 4 ohms, not 2 ohms.
The number of speaker cabs is not important, only the total impedance matters.
A 4 ohm cab or an 8 ohm cab presents exactly that to the amp - 4 or 8 ohms. Two cabs of an impedance, when connected together cuts the total in half. Two 8 ohm speakers in parallel makes a 4 ohm total. Two 4 ohm speakers makes a 2 ohm total.
item 37 in the manual states a 4 ohm lowest impedance on each channel. it even spells it out with examples of two 8 ohm speakers or four 16 ohm speakers. Both those combinations make 4 ohms.
Each channel has two jacks. The manual explains they are parallel wired. That means the two jacks for a channel are wired together. Just like the two outlets on a wall outlet for AC power. Just like a wall outlet, if ther is a 30 amp circuit breaker behind it, you can plug a 30 amp load into either outlet, but not a 30 amp load into each outlet. That would make a 60 amp load.
So if that is your confusion, you can plug two 8 ohm cabs into the two jacks of one channel, for a 4 ohm load on the amp. NOT a 4 ohm into each jack. Remember, it is the CHANNEL that has a 4 ohm limit, not each jack.
Daisy chaining speakers is still parallel wiring. That means running a speaker cord from the amp to one speaker, and another cord from that speaker to a second speaker, is exactly the same to the amp as running a cord from each jack of a channel to each speaker directly.
If only that were actually true!
Bill, we can discuss impedance curves and resonant peaks and stuff, sure, but in this context that would be over the OPs level.
I did not mean to say that a 4 ohm nominal speaker would present exactly 4 ohms at all frequencies, I meant it to say if you connect a 4 ohm speaker to the amp, consider it is 4 ohms, not something else. The amps are made to drive real world speakers, impedance curves and all.
Let me simplify it:
No, this will damage the amp. Also, don't worry about max power. The difference is negligible when it comes to perceived loudness. eg: 200 watts is not twice as loud as 100 watts. It's a logarithmic scale so in order to get twice the perceived loudness you require 10x the power.can I have 4 speakers ( 2 either side ) @ 4 ohms each to get max power?? ....
Yes.OR...4 speakers ( 2 either side) @ 8 ohms each?
- Live Sound
- PA Systems
- Ohms HELP!!
