Ohm frs-15
What I'm trying to do is get to the drivers. There underneath a cage which is under the square grille cover. I was sent some pics with the divers exposed.
I removed the cage wood screws, thinking the cage would lift off, but I may
have to pry if off. (demolition?)
Does this help?
GM
Getting the mesh off is just a pain in the butt, but if you're careful it can be done. I think I used sort of a sharp screwdriver or blade to cut the adhesive around the base.... and that's all it is.... adhesive holding it to the frame of the woofer.
GM
The cage is fastened with a thermoplastic glue. As you are in Texas, I'd suggest leaving the 'can' in a hot car for a while, then pry with a small tool using the frame edge as fulcrum pulling against a hole. Work your way around a few times then take it inside when it comes loose(put back on to carry), and try to leave the bottom on for easier handling whilst prying. This is basically what Ohm suggested when I had the can's foam liner crumbling on my Ohm Walshes.
Mine have cloth surrounds, so a thorough cleaning was all they needed-occasional buzz gone!
If you have dust issues as we do, you can get the right foam(about 2mm thick open cell) at your local serious HVAC supplies place- it's used for custom size air filters.
Have fun with these they should have plenty of life left.
Well you are in Texas. There is a good chance that some of the goopy black adhesive has migrated through the grating and really glued the whole thing down. Sooooo....time to put the whole thing in a sunny window(or if you have a halogen worklight...) and warm it up, cabinet and all. Then protect the cabinet edge and pry against the lower holes in the cage(you want to separate it anyway). Be patient, no knocking it about, it will come loose eventually.
This may be a little late, but why do you want to dismantle them in the first place? Problems?
- OHM frs-15
