If you are looking for an easy solution for insulation the chip, I found that TO-3 silpads actually fit pretty well.
I'm not saying it's the best solution, but it's clean (compared to grease/mica) and you don't need to buy a big sheet of silpad material and cut, which for a couple chips is expensive.
WorkingAtHome said:Yeah, that's a 'not-a-so-good'. The only thing that should touch the chassis (electrically) is the star ground.
the output ground is supposed to go to the star ground as well right?
Murphy's law? All I see is a few fresh new candidates for a Darwin award, or is that a little harsh?
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
Best regards,
Sander Sassen
